  #13   Ban this user!
Old 05-26-2009, 07:41 PM
5artist5 is on a distinguished road
hmm, i must be missing something. when i hook a wire from the 6 position on the G540 terminal block to the - side of a multimeter and the + side of the meter to the V+ side of the power supply fire comes from the power supply.
I double checked all the hookups and I can see no reason for this.
Any Ideas?
  #14   Ban this user!
Old 05-26-2009, 10:09 PM
TOTALLYRC is on a distinguished road
Make sure the meter is connected for volts and not amps. If you have the wires in the amps position, it is like a dead short.
Mike
  #15   Ban this user!
Old 05-27-2009, 09:27 AM
Originally Posted by TOTALLYRC View Post
Make sure the meter is connected for volts and not amps. If you have the mires in the amps position, it is like a dead short.
Mike
I double checked it and it was set to DCV.
It is a cheap meter though (HF) could it be the meter causing the fire to shoot out?
I am hesitant to put a nice meter on it now...
  #16   Ban this user!
Old 05-27-2009, 09:38 AM
A good high impedance meter should put basically no load when taking the voltage reading.
If by fire you meen sparks and a large arc, the meter could be bad.
I am not sure if you should be trying to take a reading from the 48v power supply to the #6 pin on the g540. I will have to read the manual myself as I don't actually have one.
Mike
  #17   Ban this user!
Old 05-27-2009, 09:51 AM
Here is the part of the manual that refers to outputs:
But after reading it again just now I am thinking that maybe I should use a different power supply for the relay power? It would obviously be easier to use a 12V relay than a 48 volt one...
Noob Alert or Run while you still can! anoah DIY-CNC Router Table Machines 11 05-10-2003 08:15 AM
