Old 05-21-2009, 01:56 PM
whitehedr is on a distinguished road
New here with questions
Hi, I am new machining and especially CNC. I bought a Grizzly mini mill to learn milling with. I then found out about the fascinating world of CNC and now have a burning desire to convert my mill to CNC. I have purchased most of the raw material to build the Z axis from Hoss. I do not have the ball screws or rods yet. I have not yet pulled the trigger for the X & Y material. One aspect I am struggling with is direct drive verses belt drive. I don't like the look of motors that are directly coupled to the axis ball screws.
Is there an advantage doing direct coupled rather than driving the axis with a belt. It seems that most of the conversions use direct coupling but that sure hangs the motor way out in the breeze so to speak. There are a few conversions that use a belt to drive the axis.
I would like to know the pros and cons of each method if ya'll could please discuss this for me.
My plan is to use Gecko drives and probably motors/power supply from Keling. It looks like 270 oz for X&Y and something in the 380 oz for the Z. Any suggestions on the actual motor. From what I can tell a 48v power supply is the right power as well. Am I correct on that.
I will be using Mach for the controller software.
Looking forward to discussing and learning more.
RWW
Old 05-21-2009, 08:06 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Direct drive or belt drive is strictly user preference.
2 pulleys and a belt will cost a little more than a flexible coupling per axis.
The motors should be best matched to the driver and power supply,
the G540 with 48V PS is suited for a 318 oz/in for the X and Y and a 387 oz/in for the Z.
A 1:1 pulley ratio will give the best speed.
Gearing down on the X and Y could let you use a smaller motor but you only save like $10
and the motor wouldn't be as good a match as the 318's which will work great direct drive or 1:1.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 05-22-2009, 10:16 AM
Thanks for the reply Hoss.
Will the belt drive introduce backlash into the system? And what size Pulley would you recommend? Size and number of teeth?
RWW
Old 05-22-2009, 11:58 AM
Matt McColley is on a distinguished road
from my very limited experience, it seems that the belt drive rigs usually are used with servo motor set ups.
not sure why this is, but suspect that small servos can run fast enough to deliver sufficient table speeds speeds while geared down for power.
that's my guess
then again, if you've got money to pump into a servo setup, you're likely not going to be concerned about the add'l cost of the belts, pullies and more complex motor mounts.
Old 05-22-2009, 01:27 PM
Farasien is on a distinguished road
Using a belt system, I think (you'd have to ask someone with more engineering than I have) you can effectively add more accuracy to a cut because of the larger number of microsteps due to the gearing down of the system. If you run your screw at 1:2 with your motor, you get 2X as many steps in a full 360 degree rotation (I think-and please correct me if I'm wrong on this) resulting in a smoother, truer part.
One of the effects of adding a pulley to the setup, though is you introduce another set of moving parts to the system. Every part you add will introduce more errors to the overall equation, theoretically, and thus results in more errors. As this is a hobby/learning machine though, I doubt this makes a difference unless you have a contract you want to run on the thing for tolerances as high as this might impact.
-Farasien
Old 05-22-2009, 07:37 PM
hoss2006's Avatar
You're both right on.
A servo is opposite of a stepper, it's weak going slow and strong going fast.
Gearing down gives it more power for milling speeds with plenty of rpm left for rapiding.
Gearing down a stepper will give more accuracy but in most system, direct drive is more than accurate enough with microstepping from the driver.
The g540 10 microsteps with 5tpi ballscrews will give .0001 resolution.
Doubt most benchtops would need any more.
20 tooth XL (.200) pitch would be good, be about a 1.25 OD pulley.
The 3/8 belts from SDP/SI I've used have kevlar inside to I wouldn't worry about backlash from stretch with such short lengths needed.
Hoss
Old 05-23-2009, 12:35 AM
HawkJET's Avatar
HawkJET is on a distinguished road
This is a common misunderstanding. It is due to the confusion between RESOLUTION and ACCURACY.
Adding a belt and gearing down the lead screw will more likely REDUCE ACCURACY. However it will INCREASE RESOLUTION.
Accuracy is the tolerance to which a specific positional location can be selected.
Resolution is essentially the pitch of the discrete positions available (microsteps for example) and doesn't actually indicate the positional accuracy of these positions.
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
Old 05-24-2009, 10:43 AM
My intention is to build a CNC machine with the stepper motors not hanging straight out from the end of the X&Y axis. I think that I will do a 1:1 ratio. Hawkjet, I think that doing a 1:1 I will not need to be concerned with the resolution/accuracy issue that you mention. Correct me if I am wrong.
RWW
Old 05-24-2009, 10:46 AM
Hoss, if I do a belt drive conversion will the ball screws that you offer on your website be long enough? My thinking is that they will because I am basically replacing a motor coupling with a pulley.
Your thoughts please.
RWW
Old 05-24-2009, 11:01 AM
HawkJET's Avatar
My apologies if was not clear. My intention was only to provide a vocabulary lesson. I don't know if (in your situation) there is an issue or not. There are pros and cons to both methods and as the designer, you would weigh them against your needs.
Also, accuracy/resolution questions are not the only factors in determining motor/leadscrew drive ratios. Matching the motor speed range to the leadscrew speed is a major consideration.
  #11   Ban this user!
Old 05-24-2009, 11:28 AM
philbur is on a distinguished road
I might be missing something but why would you use a belt drive with a 1:1 ratio. The motors will hang to the side and then out front anyway. In addition you will need to take care of radial as well as axial loads with the bearing arrangment. Seems like a lot of work for zero gain to me.
Phil
RWW
  #12   Ban this user!
Old 05-24-2009, 12:45 PM
HawkJET's Avatar
Not necessarily. First, I don't believe it is a lot of work. Mounts are still needed and a coupling is still needed. When Bridgeport made their Boss 3 CNC with steppers (I have one), they had a 1:1 ratio and the motors were turned so they did not stick out - they were under the table.
Also, there are potential challenges with a direct drive and coupling arrangement. Care needs to be taken to get shafts to align and couplings can also be problematic (although with hobby machines there is far less demand on them). Plus there is the added cantilevered length to handle. The bearing consideration you mention is minor if it even exists.
Most commercial CNCs use belts. IMO, I'd rather deal with a belt than a coupling because there is more design flexibility.
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 01:40 PM
EZ-Cam questions aaron p General CAM Discussion 25 11-22-2008 07:59 AM
TL-2 questions GENMACH Haas Lathes 4 08-25-2008 12:35 PM
Ver. 22: 2 questions spock BobCad-Cam 8 05-07-2007 09:17 AM
