#13
| If I go with a 1:1 belt design for X&Y axis resolution remains the same as it would with a direct drive. Correct? Accuracy could suffer with a 1:1 belt drive if backlash is introduced by the belt. Correct??? I am concerned about coupling in direct mode. Currently I do not have a lathe so getting the couplers machined properly. Maybe I should be about concerned about a belt drive system as well but right now I think that I will be able to do what I need to do to make a belt drive system work with just my mill. I do need to research motor shaft size and pulley bore size. It is possible that I will not be able to do anything without first purchasing a small lathe. RWW |
#14
| You are correct sir. I can machine the ballscrews to whatever length is needed and make the tip diameter fit the bore of the flexible coupler if you want, no need to machine them on your part. You can order them SDP/SI and McMasterCarr with different bores as well as the timing pulleys whichever route you take. Would imagine you want to use a belt system to be able to tuck the motors in under the table to give the mill a more compact footprint. Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
#15
| How would you "turn" the motor on a mini mill x-axis without having interference with the base or having it hang a long way out to the side. Phil ![]()
#16
| It's an opportunity for the designer to be creative, right?
__________________ "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944) |
#17
They are typically not exactly direct-coupled. We use a flex coupler between them to isolate the motor from misalignment and leadscrew vibration forces. |
#18
| Here is a link to a YouTube post that shows a belt drive on the Y axis. At a minimum this is what I want to do. If I can figure out a way to tuck a motor in between the frame and table for the X axis I will do that as well. I do not know who the YouTube poster is. Just want to show what I am trying to accomplish. RWW p.s. Hoss, I will be in touch with you to discuss machining of the ball screws after I get the motors and make the mounting plates. I am going on a roadtrip next week to Myrtle Beach. Be gone for a week. Last edited by whitehedr; 05-26-2009 at 06:19 PM. |
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| Brass vs Aluminium Vs Steel, questions, questions and questions... | alexccmeister | General Metal Working Machines | 25 | 08-15-2011 12:40 PM |
| EZ-Cam questions | aaron p | General CAM Discussion | 25 | 11-22-2008 06:59 AM |
| TL-2 questions | GENMACH | Haas Lathes | 4 | 08-25-2008 11:35 AM |
| Ver. 22: 2 questions | spock | BobCad-Cam | 8 | 05-07-2007 08:17 AM |
