Old 05-18-2009, 01:46 AM
mnbylcr2 is on a distinguished road
X2 Mods - additions and improvements to an X2?
Hi Guys
What are the first and then I suppose more advanced mods that can be done to an X2? When I got my mini-lathe I found a few sites with some good mods and also plans for building tooling accessories for the lathe but I havn`t found anything similar for the mini-mill.
I only know of the belt drive conversion which has been done, and altering the gibs to reduce backlash and addition of DRO bars -which I have done.
I believe you can add a spring mechanism and permanent fixtures for the spindle locking pin but I haven`t seen any plans or pictures for this mod - it is certainly something I would like to try.
I suppose you could say I am looking for things to do for the sake of it, but it is a hobby and I`m enjoying it!
Mnbylcr2
Old 05-18-2009, 01:49 AM
Teyber12's Avatar
Teyber12 is on a distinguished road
CNC it
Old 05-18-2009, 02:13 AM
tumutbound's Avatar
tumutbound is on a distinguished road
Increase Y travel - this one doesn't look too difficult, provided you have a spare mill to do the work on
Column brace
There's a number of spindle lock mods including this one from Hoss.
But as Teyber12 said, CNC it. You know you want to...
Regards
Geoff
Old 05-18-2009, 06:18 AM
lbrc is on a distinguished road
Coolant (definitely a must have/do), power draw bar (not absolutely necessary but…), both can be either purchased or 100% DIY projects.
CNC!!!
Old 05-18-2009, 11:11 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
X2's are made to CNC. I'm with the others, cnc it ASAP. Or buy the extra one I have....
Old 05-18-2009, 11:45 PM
ibuildstuff4u is on a distinguished road
You can upgrade the power supply and get more torque and speed out of the motor. Pretty easy to do and can be done cheap if you watch for a good deal on E-bay for the power supply board.
Dale P.
Old 05-18-2009, 11:50 PM
what are the specs?
Old 05-19-2009, 01:37 AM
Farasien is on a distinguished road
stiffen up the column
If you want a simple mod that can make your setup alot more solid, try stiffening up the column/base. Use epoxy, epoxy-modified cement or just plain 'ol cement and fill the lower half of the column- gets you a lot more stability. For extra added measure, chuck the thick washer on the back of the column and replace it with a steel or aluminum plate- its shape makes it act like a spring. If you wanna go full-on ridiculous (like I did) you can rig up either an angle plate, a brace system or something similar to put the coup-de-grace to deflection in the column.
A belt drive (look at Sterling Steele or some of the others mentioned through the forums for the X2) is almost mandatory if you want to not go out of your mind while machining with it. If a belt drive isn't in you plans, if you don't want the temptation of taking a hammer to it WHEN (not if) you break a drive gear, I'd suggest replacing the plastic gears with metal ones- littlemachineshop sells 'em.
An air spring conversion kit is a good investment- it gets you a bit more Z travel. If you wanna upgrade even more, you could use a counterweight system.
DRO's are a good idea if you are going to keep it a manual machine.
If you want to do any 4th axis work, a rotary table or something similar is needed, and can be cheap if you hit ebay alot.
...and of course, CNCing it is always a good idea. If you like to mod your machine, you're likely to go that route in any event eventually...
-Farasien
Old 05-19-2009, 04:37 AM
Thanks for your replies so far - please keep them coming.
I already have the air spring conversion so I think my next one will be the belt drive kit - unfortunately doesn`t look to be available from a UK supplier - can anyone clarify this?
I have still not seen anyone mention or send a link to the spring loaded spindle locking pin?
I may consider the column support - I could do with some plans though! - I`m not an engineer by profession and therefore struggle replicating pictures without detail or ideally plans.
Please do link up - I am familiar with "search" but you know what it`s like, most of you guys have been on here for longer than me and know what posts are best for the info.
....keep it coming. Chris
Old 05-19-2009, 04:59 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Chris,
I though you might like this.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  #11   Ban this user!
Old 05-19-2009, 07:04 AM
tumutbound's Avatar
I got mine from LMS. Quick service, reasonable shipping rates.
Check my last reply or go directly to Hoss and borrow his design.
Go the yahoo group I linked to and ask the person who posted the photo. They're a helpful bunch over there too.
Regards
Geoff
  #12   Ban this user!
Old 05-19-2009, 07:05 AM
tumutbound's Avatar
Originally Posted by jalessi View Post
Chris,
Jeff...
Wish I;d seen this one before I bought my belt drive kit!
Regards
Geoff
Joe's CNC Model 2006 (Mods & Additions) joecnc2006 Joes CNC Model 2006 139 03-01-2011 10:11 AM
Owners manuals need improvements! AMCjeepCJ Milltronics 8 11-21-2009 11:34 PM
Additions/Modifications to David Steele's Solsylva CNC DougO CNC Wood Router Project Log 18 04-13-2008 05:46 AM
Taig Headstock Improvements?? scubasteve_911 Taig Mills & Lathes 6 08-22-2007 01:10 PM
More Improvements rodneydeeeee Dolphin CADCAM 3 03-22-2007 05:40 AM
