  #13   Ban this user!
Old 05-19-2009, 06:36 AM
tumutbound's Avatar
tumutbound is on a distinguished road
My own X2 plans
For what it's worth, here are the mods/improvements I plan to make to my X2:
  1. Belt drive - already done using LMS kit. Real reduction in noise which I'm sure my neighbours appreciate.
  2. DRO and scales - I've got a Shumatech DRO kit to build and 3 scales from Shars. Still to design and make some suitable mounts. Lots of ideas both here and in the Yahoo (Shumatech and GrizzlyHFMiniMill) groups.
  3. Y travel extension - Previously mentioned the link to this one. If I do this then I'll certainly do 4.
  4. Column support - a 15mm - 20mm steel plate to mount the mill on and a large angle bracket should do the trick. Not sure about the epoxy filling though.
CNC is on the list but I want to get some manual milling experience first - while I save money to buy the CNC bits.
Regards
Geoff
  #14   Ban this user!
Old 05-19-2009, 11:48 AM
Farasien is on a distinguished road
I wouldn't bother buying the CNC parts... If you have a decent set of accurate calipers, your mill has a working DRO (or you really know how to do accurate machining without it) and know a few fundamentals, you cam make them for the cost of a few plates of aluminum and a weekend's worth of time. That is, if you aren't considering upgrading to ballscrews. In any case, go check out Hoss's site (www.hossmachine.info)- he has most of his plans for free on there and sells stock kits and plans for a whole bunch of other interesting mods.
The nice thing about learning how to manufacture stuff is you'll find, more and more, you don't have to buy much of anything anymore outside of raw materials and the occasional tool.
-Farasien
  #15   Ban this user!
Old 05-19-2009, 12:43 PM
tumutbound's Avatar
When the time comes to CNC, I hope to make the mounts my self. The bits I have to buy are the motors, controllers, ballscrews etc.
Regards
Geoff
  #16   Ban this user!
Old 05-19-2009, 01:23 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Originally Posted by jalessi View Post
Chris,
I though you might like this.
Jeff...
BeltDrive1.pdf‎
I built my belt drive from that design from J. Rollett posted on the GrizHFminimill Yahoo Group.
I made a few changes to make fabrication easier.
Some of the pdf dimensions are not correct such as the motor mount holes.
I left out the provisions for mounting a Hall IC Sensor but would leave that in now to output RPM.
JR did a great job, it's as nice as LMS's.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  #17   Ban this user!
Old 05-23-2009, 06:17 PM
ibuildstuff4u is on a distinguished road
Here is the link for adding a new power supply to the 2X mill. Sorry I thought I added it to my last post. It's a pretty easy project to do and made a big difference to my machine.
Dale P.
http://www.harrisson.biz/controller/power.htm
  #18   Ban this user!
Old 05-23-2009, 07:06 PM
acondit's Avatar
acondit is on a distinguished road
Originally Posted by tumutbound View Post
Increase Y travel - this one doesn't look too difficult, provided you have a spare mill to do the work on
Column brace
There's a number of spindle lock mods including this one from Hoss.
But as Teyber12 said, CNC it. You know you want to...
Here is a link to a post that I made on my Y axis extension and a drawing showing the measurements.
Alan
http://www.alansmachineworks.com
Joe's CNC Model 2006 (Mods & Additions) joecnc2006 Joes CNC Model 2006 140 02-22-2012 04:22 PM
Owners manuals need improvements! AMCjeepCJ Milltronics 8 11-21-2009 10:34 PM
Additions/Modifications to David Steele's Solsylva CNC DougO CNC Wood Router Project Log 18 04-13-2008 04:46 AM
Taig Headstock Improvements?? scubasteve_911 Taig Mills & Lathes 6 08-22-2007 12:10 PM
More Improvements rodneydeeeee Dolphin CADCAM 3 03-22-2007 04:40 AM
