  #13   Ban this user!
Old 05-18-2009, 06:13 PM
idtkid's Avatar
idtkid is on a distinguished road
Heres the measurements of the CDCO DRO: 7.5" x 4.15" x 1.5"
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
  #14   Ban this user!
Old 05-18-2009, 06:18 PM
fretsman's Avatar
fretsman is on a distinguished road
Thank you sir, very much appreciated for all the info-
Dave
Dave->..
  #15   Ban this user!
Old 05-18-2009, 09:34 PM
idtkid's Avatar
Not a prob, if you need to know anything else just let me know!
  #16   Ban this user!
Old 05-20-2009, 11:14 AM
dyne is on a distinguished road
I just got my scales today and cracked one open. There's probably no way to extend the LCD from the scale; there's no actual physical wire connection between the circuit board and LCD. It must send the signal to the LCD panel using inductance or something.
  #17   Ban this user!
Old 05-20-2009, 12:49 PM
idtkid's Avatar
You sure there arent surface mount "solder tabs" on the back of the LCD that are touching the board?
  #18   Ban this user!
Old 05-20-2009, 01:45 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
I found these Remote Display Units at tresnainstrument.com that might be worthwhile.
Building a Shumatech would still be cheaper but these are simple and ready to go.
Found a single unit with scale on Ebay so there may be more.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  #19   Ban this user!
Old 05-20-2009, 02:03 PM
yeah, there's actually what looks like a black rectangular piece of plastic between the LCD and circuit board but it does not look like there's any sort of metal connection (either on the black piece of plastic or the lcd)
  #20   Ban this user!
Old 05-21-2009, 02:06 AM
lsces is on a distinguished road
The black strip between the display and the pcb is alternating strips of conductive and isolating material. There are a lot of connections to the display, so simply trying to extend it will not work. The safest way to extend the display IS to use the remote modules that the data port was originally designed to drive.
Of cause the main advantage of the DRO350 over these remote displays is the fact that it's LED, so can be seen even in the back of a workshop if you have bright light on the machining area.
http://medw.co.uk - Home of electronics for Model Engineers
  #21   Ban this user!
Old 05-21-2009, 02:13 AM
MrWild is on a distinguished road
EMC2 has a read out screen and will read encoders. EMC2 is free. It might be a bit of a job to be the first one to get it all together with the chinese scales, but it should work. EMC2 works with glass scales used on Crusader M retrofits, so it should read and put put for the cheap chinese scales
  #22   Ban this user!
Old 05-21-2009, 02:20 AM
You would probably need YADRO to convert the chinese scales to something that EMC2 ( or Mach3 ) can read, but I believe a couple of people are working on modules to take the data and make it available in both.
Of cause once you have YADRO, you can simply use it's own display program
Lester Caine - G8HFL
http://medw.co.uk - Home of electronics for the Model Engineer
  #23   Ban this user!
Old 05-21-2009, 04:15 AM
fretsman's Avatar
Not sure about the others but the reason I'd like one of these remote DRO's is I have the digital scales set up on my manual 9" South Bend lathe, not a CNC.
Dave
Dave->..
  #24   Ban this user!
Old 05-21-2009, 05:16 AM
bertmiller is on a distinguished road
i have chinese dro's on my mill.
these are not realy menth for cnc because there data lags behind the actual position.
i managed to write my own cnc program that works around this.
http://www.youtube.com/user/BertMLemon
mostly the flex in the endmill and aluminium is larger then the error of the table.
and the dro's are realy great for manual opperation.
Miter saw for solid ALU bars? PEU General Metalwork Discussion 5 08-14-2008 07:02 AM
Cheapest 3 axis 4 wires driver? q-bert General Electronics Discussion 1 06-06-2008 07:23 PM
NEW 2 & 3 axis digital readout kits from DRO PROS dropros Product Announcements & Manufacturer News 2 01-06-2008 01:12 AM
Small Threading Bars Bridged Metal Working Tooling 3 12-10-2006 12:50 AM
Tool bars MPE racing General CAM Discussion 6 06-24-2003 06:20 PM
