| Hi, I am thinking about taking a lathe, say a HF 8x12, stand it on the tail end, attach a xy table to the carriage and use it as a knee mill. This would give 8in spindle2column, 16in Ztravel ; almost a G0619 for about half of the price .Have anyone here done something like that? ht |
| No quill feature? Just moving Z by using the knee? |
| I don't think there is anybody crazy enough, even on this forum, to attempt something so off the wall. Why bother to stand it on its tail, plenty of people use their lathes the right way up for light milling operations. Why bother with an xy table, you already have the cross-slide for the first axis and a simple, readily available vertical slide would provide the second axis. etc, etc. Good luck with your plan. It will be interesting to see the finished result. Phil
| Kmill I think this mill is in the wrong forum. After some calculations the mill turned out to be more than a bench top. Mill Specifications Spindle Travel................................................. 0 in. Swing............................................................16 in. Longitudinal Table Travel..................................17-7/8 in. Cross Table Travel...........................................7-3/4 in. Vert. Table Travel...........................................15-1/4 in. Knee Travel....................................................15-1/4 in. Head Tilt.......................................................no. Max. Dist Spindle To Column...............................8 in. Max. Dist Spindle To Table............................... 18-3/4 in. No. Of Vert. Spindle Speeds..............................5 Steps Range Of Vert. Spindle Speeds................120 - 2000 RPM Quill Dia.......................................................4.0in. Spindle Taper............................................... MT3 Spindle Size...................................................1.5in. Motor.........................................................3/4HP Column.....Heavy Duty Cast Iron Rectangular Box Type Dimensions L/W/H..............................20in/14in/56in ht Last edited by htrantx; 05-17-2009 at 08:41 AM. |
