I've watched these forums for quite some time over the last year. I finally got around to actually buying and retrofitting a machine. It's still a work in progress but I thought I'd go ahead and start a log for anyone else who might be working on one of these. First of all, a few links. I would not have gotten nearly as far as I have if it weren't for a thread started by Alex Cole regarding his retrofit of a Dyna 2400. Here is a link to his thread: http://www.cnczone.com/forums/showthread.php?t=33770 I've also made many other posts here regarding various components, questions, or problems as they've come up. Instead of trying to include all of that information I'm posting links to my other posts. Here they are. Stepper wiring RE shield/ground/connector CNC4PC C3 Index Pulse Card - Help Stepper Motor "cogging" issue CNC4PC C23 Power Connections Speed Controller Wiring - check me 12vdc from 5vdc Spindle Motor Help Dm2400 Line By Line Execution???? Source for metric Delrin nut |
| I found the mill on Craigslist. I went and took a look and it was in decent shape. The first thing I did when I got it home was to remove all the stock electronics and clean it up. I'm not sure what the difference is between the 2400 and 2100. The 2100 doesn't have the built in oiler that the 2400 has. Other than that, not sure. I'm going to post some pictures. A note on these pictures - while they are reasonably good size pictures you can click the link below each picture to go to the full size image. BEWARE: The full size images are 12MP images and range in size from 2MB to 6MB. ![]() http://www.travisreese.net/dyna/P1000870.jpg This is a view of the base of the machine with x and y axes removed. They look like hand scraped ways. |
![]() http://www.travisreese.net/dyna/P1000872.jpg Here's an overview of the machine with the axes and spindle removed. ![]() http://www.travisreese.net/dyna/P1000873.jpg Here's one of the axes. You can see the housing for what dyna calls a "supernut." It's their anti-backlash nut. |
![]() http://www.travisreese.net/dyna/P1000876.jpg Here's a view of the Z axis with the electronics cabinet removed from the back of the mill. |
![]() http://www.travisreese.net/dyna/P1000882.jpg The oiler port on the bottom of the table which lubricates the ways. |
#11
![]() http://www.travisreese.net/dyna/P1000888.jpg ![]() http://www.travisreese.net/dyna/P1000889.jpg These are both views of the "supernut" anti-backlash nut removed from its housing. You can see two tangs on the leftmost metal fitting in the bottom picture that sit in the two keyways on the left half of the plastic nut. You'll notice that the right side of the plastic nut only has one tang on it. The other is broken off. This nut had to be replaced. The leadscrews on this machine are M12x2.5 which is not a standard size. I couldn't find any source for them other than going back to Dyna to get a replacement. |
#12
![]() http://www.travisreese.net/dyna/P1000909.jpg Here is the replacement nut sitting below the original. |
| Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos | ckm | Knee Vertical Mills | 190 | 02-18-2012 12:42 AM |
| Machine Design, Build, Retrofit or repair services offered. | PoppaBear10 | Employment Opportunity | 1 | 04-05-2011 12:48 AM |
| Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 | GreenLead | Benchtop Machines | 31 | 11-26-2008 11:55 PM |
| Need Help!- camsoft retrofit to a anilam crusader retrofit | bowlingmac | CamSoft Products | 44 | 07-24-2008 09:00 PM |
| Retrofit a Dyna 3000 Lathe | starlight | Open Source CNC Machine Designs | 0 | 05-06-2008 06:45 PM |
