Results 1 to 5 of 5
Thread: Where do I get longer leadscrews for an X3?
    Mar 2009
    My X3 has 9 inches from the spindle to column but I'm only getting 5 3/4" of Y travel. The table can go at least 3/4" before it touches the column and farther the other way if I have a longer leadscrew. Where do I get a 10 thread per inch leadscrew like that and what does it cost?
    Oct 2006
    You might be able to use a replacement X axis screw. You should verify they are both the same thread (right or left handed). I believe the X is RIGHT hand thread.
    Frank
    Mar 2009
    Quote Originally Posted by Toymanf View Post
    Frank
    Thanks Frank! How did you get your 7.75 and 18.9? Is it with the original table?
    Oct 2006
    Yes, I used the original table. I converted my x3 to cnc and changed to ball screws with double nuts.
    Frank
    Registered M100's Avatar
    Oct 2006
    UK
    Frank
    Both the X AND Y axis screws are RH threaded despite one well known published article on the X3 saying otherwise!
    1. Longer parallel cable or longer steper wires?
      By jvanick in forum Hobbycnc (Products)
      Last Post: 09-13-2008, 06:51 AM
    2. New longer Y
      By CNCadmin in forum Benchtop Machines
      Last Post: 08-12-2004, 07:40 AM
    3. adding a longer bed
      By balsaman in forum Mini Lathe
      Last Post: 04-09-2004, 10:31 PM
    4. Longer Lathe Bed
      By boyd32450 in forum Benchtop Machines
      Last Post: 02-19-2004, 02:17 PM
