Old 05-03-2009, 11:37 AM
skmetal7 is on a distinguished road
Another Surface Finish Question
x2 mill cnc'd
new 1/4" solid carbide em .002" finish pass DOC (.01" rough DOC)
4600 rpm (max rpm) 10 IPM (on final pass)
6061-t6 aluminum
and i get this surface finish.... pics (one pic is right after the final pass, 2nd is after light sanding)
my mill is trammed. i cant feel any "humps" between passes. am i running too slow? Ive used wd-40 as a cutting fluid. my sfm is ~300 so i guess its lower than recommended for al. but would that give me these circles?
ID:	80700   Click image for larger version
Old 05-03-2009, 11:46 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Those are some light cuts your taking and your still getting that? Up your IPM and try something other then wd-40.
-Jason
Old 05-03-2009, 11:53 AM
yea i like to do many quick passes for roughing, then take a slow finish pass. maybe the aluminum is galling because its rubbing, that's all i can think of
Old 05-03-2009, 12:50 PM
MRM RCModels's Avatar
MRM RCModels is on a distinguished road
Originally Posted by skmetal7 View Post
x2 mill cnc'd
6061-t6 aluminum
You're cutting to slow. For face milling you want the cutting tool to be at least 1.5 times the size of the part. Try increasing the size of the cutter, and make multiple (lighter) cuts at faster speeds. I use a 2in face mill feeding at 20 IPM with four 0.0005in passes. Get an extremely smooth finish. Even with 20% overlap.
Old 05-03-2009, 01:52 PM
bertmiller is on a distinguished road
to me it looks like there is something wrong with your table.
try to loosen or tighten it.
Old 05-03-2009, 03:25 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
For a 2 flute, your feedrate is what my feed/speed calculator recommends. Go twice as fast with a 4 flute or 20 IPM. That kind of job you can use a 4 flute, BTW, and it's helpful.
Looks to me like things are bouncing. There are periodicities in the pattern. It's almost like something creates a dwell or change in feedrate every so often.
Check your gibbs and make sure they are tight on all axes.
Are you running ballscrews? Check the preload.
There may be enough play in your spindle bearings, quill, or z-gibbs for the cutter to bounce up and down slightly.
Cheers,
BW
Old 05-03-2009, 03:26 PM
fretsman's Avatar
fretsman is on a distinguished road
Agreed, either the x or y axis table or screw has "hump" in it or something to that extent. Looks like it's "bouncing".
Maybe put an indicator on your headstock and run it across the table (both ways X and Y directions) to see if you can see any errors.
Dave
EDIT: looks like Bob beat me by a minute - lol!
Dave->..
Old 05-10-2009, 03:30 PM
sansbury is on a distinguished road
I got results like this on my X2 when the spindle was not tightened up enough. Is there any kind of grinding or rattling noise when the spindle is running? If you're not cutting all you should hear is the motor. I'm assuming based on the RPM that you are running a belt drive.
Old 05-10-2009, 06:39 PM
Regnar's Avatar
Regnar is on a distinguished road
Have you tried facing the parts in the other direction. If you are going using the x axis try the y axis next time. This will rule out if its the Head or the particular axis. Along with all the other suggestions you should also check that lead screw to make sure it is parrel to the table. If it is canted it will lift up on the table every time you make one full revolution, also if you have problems when you tighten down the gibs this might be your solution.
Old 05-10-2009, 07:19 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
I don't have a x2 but this screams TRAM to me... anyone else?
  #11   Ban this user!
Old 05-10-2009, 09:07 PM
SScnc's Avatar
SScnc is on a distinguished road
Well I'll stick my .02 cents in here also. I think if it were tram it would be more consistent but as Bob W pointed out it's not exactly. I think it's the Z gib not tight and the spindle head is "bouncing".
I'm curious to find out what skmetal7 finds out.
  #12   Ban this user!
Old 05-11-2009, 06:03 PM
philbur is on a distinguished road
I vote for lack of spindle bearing preload.
Phil
64 RMS Surface Finish? pzzamakr1980 General Metalwork Discussion 3 01-13-2009 04:19 AM
Surface Finish life3970 Mini Lathe 2 11-07-2007 12:00 PM
Surface finish skmetal7 Mini Lathe 7 09-10-2007 12:56 PM
Surface finish chakaloso General Metal Working Machines 0 06-12-2007 08:54 PM
Surface finish d.a.v.e Mechanical Calculations/Engineering Design 1 11-10-2006 01:35 PM
