Even though that diagram is different than the one that came with my G8689, my motor does connect to the main switch.
I'm not sure if this answers your question, if not, let me know and I'll try to help some more.
Steve
I have all the parts for the X2 spindle motor controller but I am not sure about the wiring on the on/off switch. In this diagram it clearly states connections to terminal 6 and 7 but I do not understand where the other two wires from the switch go. IT looks like they indicate that two wires connect to the motor. But that does not make sense to me.
Any insight would be appreciated.
Dan
Steve
Littlemachineshop has some wiring diagrams for these motor controllers. You can find the controller under replacement parts for the X2, and I believe there is a link on that page to some wiring diagrams.
Dan,
Have you seen this:
http://anivo.com/reed/G8689_cont/g8689_cont.htm
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Dan,
This is good info also.
http://www.modelbrasscannon.com/ServiceManual.pdf
Jeff...
Very good links Jeff ! I can't speak for Dan but I sure appreciate you posting those, I didn't know about them.
Steve
Wow, that is a great find on the documents!
I did have a Homer Simpson moment (DOH!) and figured it out.
Thanks for the replies I do appreciate people taking the time to help out!
Dan
ps check out the Soundcard Oscilloscope at http://www.zeitnitz.de/Christian/Scope/Scope_en.html
Happy to help you guys out,
Jeff...
