Old 03-30-2009, 05:00 PM
shadowless is on a distinguished road
DC servo direct drive for Taig/sherline mill
I am going to do a cnc conversion for a Taig Mill, when i approached keling.com regarding the appropriate DC servo motor for direct drive of the mill, I was told that dc servos need to be reduced, they are too fast for direct drive.
I was puzzle so when to ask around and Al confirm that it is possible as long as the maximum torque is the same as a equivalent stepper motor that would drive the system.
My research point me to a 350oz-in peak torque dc servo such as these:
1. KL23-130-60 (NEMA23) dual Shaft
Skewed Rotor Design, 60V/20A
Constant Torque: 50 oz-in
Peak Torque: 350 oz-in
No load Speed: 4700 R.P.M
Terminal Voltage : 60 VDC
Continuous Current: < 4 A
Peak Current: > 20 A
No load Current: 0.5A
Weight : 1.4 kg
2.Nema 23 350 oz/in Peak Torque 60VDC Servo
from http://www.homeshopcnc.com/servo2.html
I understand that these motor need to be reduced 2:1 now.
Does it make some of the servo systems sold on the market today far from complete setup less the required 2:1 reduction system.
So far the only plug and play dc servo systems for small mills is from IMservice.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Direct drive a servo...is it possible bgolash Servo Motors and Drives 0 08-21-2006 08:41 AM
Direct drive vs. Belt Reduction - Mini Mill Conversion sanddrag Benchtop Machines 2 02-10-2006 10:00 AM
Direct Drive for Hi-Res Mill jdownie General Metal Working Machines 1 08-15-2005 05:49 PM
Direct Drive Servo or pulleys sendkeys General Metal Working Machines 7 05-06-2004 08:15 AM
