Results 1 to 4 of 4
Thread: X2 Table out
    Aug 2008
    X2 Table out
    Hi all, I have an X2 clone that i picked up from Princess Auto (Canadian Store)
    Ive managed to get it trammed pretty well, I am trying to face mill some aluminum and i got mounted in a vice.
    My problem is that between the cuts there are small ridges. Its seems like either the Table is tilted or the Spindle is tilted.
    When i mount a dial indicator to the spindle and measure the table, the back of the table is lower then the front by .005.
    Ive tried to adjust the machine to get rid of this but nothing seems to help it.
    I think i may need to shim something, Would shimming the Vice help? Or perhaps shimming up the back side of the X? Z Column? im not sure.
    How do i correct this? it says nothing about adjusting this in the manual.
    Gold Member hoss2006's Avatar
    Apr 2006
    Shim under the column to fix the tram permanently, under the vice just for a quick fix for this job.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Mar 2009
    im new to milling and want to learn the trade, so try not to laugh at my question...i have a question on the setup of my x2. how to i unlock the y axis i believe...the handle that moves the table forward and backward...it does not want to move and i cannot figure out how to get it moving. thanks for any posts
    Apr 2006
    Is the little lock handle engaged?
    the gib screws may be too tight, the 3 setscrews on the right side of the saddle.
    loosen the nuts and back off the screws until it moves then snug the nuts back up.
    don't loosen too much or you'll get slop, the table will wiggle back and forth.
    Hoss
  1. My cnc table
    By scrambled in forum Plasma, EDM and other similar machine Project Log
    Last Post: 07-24-2010, 09:11 AM
  2. DYNA CNC TABLE WITH WATER TABLE
    By DISCONNECTED in forum General Waterjet
    Last Post: 06-06-2008, 09:04 PM
  3. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 01:35 PM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 01:21 PM
  5. help 4x4 table
    By monte55 in forum DIY CNC Router Table Machines
    Last Post: 08-08-2006, 12:27 PM
