http://www.littlemachineshop.com/pro...3132&category=
I was shoping around and fount this setup and am wondering if anyone else has used this setup. I am setting up a MaxNC 10cl and found this one with some direction from this site. I hope to make a 4th axis for my machine in the near future.
Is it better to get a 3 jaw chuck or a 4 jaw?
I would have to ask them on the site I found it. What rotary table do most people use to cnc on one of these benchtop mills?
Sherline has a nice one with motor already installed. I have as yet to use mine but hopefully soon.
Not sure of the price as mine came with the mill I picked up used.
Mike
Sherline DOES have one of the BEST CNC rotary tables.
http://www.sherline.com/8730pg.htm
But I would buy the CNC READY version, and then put a motor on it that matched my power supply.
http://www.sherline.com/3700cncpg.htm
If you shop around for a discount you can get for less.
Now it is only a 4 inch table though. A 4 inch table will only easily adapt to a 3 inch chuck, and that will limit the diameter of work.
The more jaws a chuck has, the gentler it will hold the work. Use a three jaw chuck to hold only round work. A 4 jaw can hold both round and square stock. An independant 4 jaw chuck can adjiust each jaw for perfect concentricity. A 4 jaw scrolling chuck is self-centering.
There are also six jaw chucks that will hold round work like tubing more gently.
CR.
The self-centering chucks have limitations on how accurately they center. Independent chucks are slower to mount but can be "perfect". 4-jaw indy is easier to adjust than a 3-jaw indy.
The 4-jaw indy can mount rectangular-but-not-square work. A 4-jaw self-centering cannot.
Those 3-jaw self-centering ones have replaceable jaw blocks, and that can come in handy to have custom jaws for specific jobs.
Nick recommended that if you only get one, get the 4-indy, and I see why. Round or square or rectangular and can give near-perfect accuracy.
Thanks Guys.. This has answered allot of my questions so far. I am not ready for a cnc table quite yet so I am wondering if anyone has used this product from Littlemachineshop.com?
I will definately go for the 4 jaw after all the supporting reasons for why it is better and I will look for the indy style jaws to allow for odd shaped work to be held.
I have been looking hard for a low budget setup to get me rolling and later I will either go 4th axis cnc table or just build a full 5 axis machine using the controller from my maxnc until I build a new controller board.
For getting started would anyone recomend a setup like this?
The rotary table you have posted is a cheap copy of a Phase II
You should look at the model 1927 instead, they are very good.
http://tinyurl.com/d7nc4r
The backlash is adjustable and it is very solid.
Welcome to the Zone,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Phil,
You are 100% correct, the 1810 is not very good.
He should be looking at the 1927 model.
I will correct my old post.
Jeff...
It's interesting that the cheaper model (1810) is ground all over, presumably to look more attractive to the less wary.
Phil
PS: Possibly a perfect example of: all that glitters in not gold.![]()
ok. Thanks guys.. Thats what I was wondering. I dont want to buy a setup that will cause me more trouble than it is worth. I have some work I want to do that involves cam grinds and I would like it to run as true as possible.
I had thought about building one myself but with out a lathe I really dont want to attemp it. To be totally honest I want to build one of those scale engines. I want to model a Mitsubishi 4g63 turbo motor with dual overhead cams and all. I have been machining for 5 to 6 years and now have broken into the cnc scene with my Maxnc. I got it really cheap considering it was only a few months old with about 12 total hours on it. It has the updated electronics and the larger spindle motor. I plan to strengthen up the z axis and I'm building a block that allows me to move the z axis up and back for more movement. I will probably keep it for cutting printed circuits boards when I am done building my 5 axis machine. I just have to figure out what kind of controller I want to build and what to go with for steppers. I am doing allot of reading and looking for the best to get for matched steppers and then I can start on my build. I wish I had seen more of fixittt's posts on the max before I picked mine up but with the software and the machine with all tooling I made out really good at 1500 for all of it.LOL.
