Old 03-11-2009, 08:57 PM
MRM RCModels's Avatar
MRM RCModels is on a distinguished road
Lost My Balls!
Figured this would be a good place for this since so many of you have the X3 CNCfusion Deluxe Ballscrew upgrade. All of my Ball Bearings fell out of the Ballnut.
How do I put them back in?
Thanks,
Kelvin
Old 03-11-2009, 09:13 PM
escott76 is on a distinguished road
Thanks,
Kelvin
I put the nut on the screw, take the return tube off, and start pushing them in, rotating the screw. Make sure to not let the end ones keep going past the second hole for the return tube. You can use a toothpick or similar small object to pack them in. When the nut is full there will be a couple balls left over. Some grease will help them stick in the return tube. Reinstall and you are good.
Old 03-12-2009, 09:47 AM
project5k's Avatar
project5k is on a distinguished road
hehehe, yea, been there done that, once you do it, its not that bad, just make sure that you work on a towl or something so that if you drop them again they dont take off again.
The uncertainty feeling before you do it is far worse than actually doing it.
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 03-12-2009, 12:17 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Using a little grease as suggested before is a good idea.
LOL, had to laugh when I saw the Thread Title though.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 03-12-2009, 05:06 PM
scudzuki is on a distinguished road
It is pretty unpleasant when they start falling out and you don't know how you're going to get them back in, but fortunately it's actually quite easy once you get started.
Joe
Old 03-12-2009, 09:29 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
http://www.cnczone.com/forums/showthread.php?t=73910
How? i thought you had those really expensive limit switches
Old 03-15-2009, 02:56 PM
stag53 is on a distinguished road
Hey, just as a checksum... there are 16 balls per circuit. I lost my balls too when I was installing the kit. Miraculously recovered all of them.
I suggest a small needle nose pliers to drop them in, a toothpick to poke them in place, and a comfortable couch in front of the TV. It's actually kind of relaxing... if all goes well
Old 03-15-2009, 03:28 PM
pete from TN's Avatar
pete from TN is on a distinguished road
If I did that on the couch I would be tearing the couch apart!!
I had this happen so far in my first conversion and I gotta tell ya until I figured it out it was a real PIA!!. My advice is to put the parts on the kitchen table on a terry cloth towel so the little balls will not roll all around on ya. The advice to remove the screws and return tube is fine and then you just need to start dropping balls into the nut with the screw installed in there. It is important that you do not let the balls from the one hole travel all the way thru and go past the second hole. They will just fall out when you try to turn the nut on the screw(ask me how I know). SO just keep dropping them in and carefully watch the second hole to make sure a ball or three does not go past the other hole. Then when you get all the balls in you can do the heavy grease thing in the return tube halves and stick the rest of the balls in there. Close the halves and carefully drop the return tube into place. Hold it down with one hand while you carefully install the little shcs into their holes. If you did it right none of the balls will be beyond the screw holes and will be captured in the nut. Make sure by rotating the ballnut along the screw over the terry cloth towel in case you missed one. It literally took me three or four tries to get it right so don't feel bad if you goof it up. Just make sure you run it back and forth a few times over the towel in case a ball or three falls out of the nut... Good luck man!!!
Old 03-15-2009, 11:54 PM
Thanks guys for the replys. I got everything back together minus one ball bearing . I'm going to try it and see if it makes a difference; hope not....here's a reply I got from Mike at cncfusion also
First off, you must put the balls in from opposite the flange end. You will need to remove the ballnut from the ballscrew using the supplied tube, and flip it around once you get all the balls reloaded.
There are four separate circuits of balls inside the nut, each separated by a grey plastic return tube, ( four grey things you can see from the outside of the nut). Take all the balls out if they haven’t fallen out yet. Divide them into four equal piles on a towel, preferably on a table or counter top. Thread the ballnut slightly onto the end of the Y ballscrew, and drop the first pile of balls into the nut. Using your finger, push the balls into the threads of the nut, in the first circuit. This is the most difficult circuit to reload, because it is deepest inside the nut. You will need to thread the nut up and down the screw as you reload them, to distribute them evenly. Once you get the first circuit reloaded, repeat with the 2nd , being careful not to unthread the nut too far and release the first circuit of balls.
Repeat for the remaining two circuits.
It is a pain, but you should be able to get them back in.
Old 03-16-2009, 11:51 AM
tobyaxis's Avatar
Moderator
Hmmmm......missing one ball. That may or may not pose a problem. If I were you I would start out slow and light and gradually increase it's duties.
Good Luck and I hope it works out for you.
This thread title really makes me laugh, sorry
Toby D.
Schwarzwald
  #11   Ban this user!
Old 03-16-2009, 11:57 AM
laszlozoltan is on a distinguished road
no no no, find that other ball 1st.
Old 03-16-2009, 06:10 PM
tobyaxis's Avatar
Moderator
He has a point.
Toby D.
Schwarzwald
Need to refill a linear bearing (lost my balls) sswitaj Linear and Rotary Motion 1 05-11-2008 09:18 PM
New balls for screw rod ? vroemm Linear and Rotary Motion 15 01-15-2008 04:55 AM
How many balls in nut? phantomcow2 Linear and Rotary Motion 10 04-19-2007 10:30 AM
Lost Balls for THK HSR15 Help planekrazie Linear and Rotary Motion 2 08-13-2006 09:14 PM
Ballnuts: Do you really need all the balls? geohot Linear and Rotary Motion 3 12-27-2005 12:34 AM
