Keling says that the new 318 oz steppers will be available in 15 days. My question is should I wait for them to come out and get them for my Taig? Ot am I really better with the 270 oz ones since the Taig is so light? The 270s will be faster wont they? Do I need the extra torque? |
| With the 20 tpi on a taig the 270's should be really good. The 425's on my taig are overkill and are slow to the point of tears at least with the xylotex driver. I have since moved the motors over to my router and I am using the g251 to drive it on 50v, what a huge difference, but they are still limited. Back to the Taig. What ever motor you chose, the torque is multiplied by the 20 tpi screw, so the 318's will more than likely be overkill and will probably limit your rapids, but I am not sure. I am actually trying out some single stack nema 23's that I don't have torque specs on to see what will work with the xylotex driver and ~30v power supply. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| The 318's are the closest match available to the G540's output, with 3.5 amps and 54 volts. the 270's are 3 amp and 60 volt, the 318's should give the best speed you should expect from the g540. yes more torque than is needed for a taig but should have the best speed. Should be perfect for an X2 X and Y but probably be a little weak for an X3.
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
Ehhh, maybe 5 IPM, with leadscrews percentage wise, you don't have a lot to gain. The highest claim for a taig with steppers i've seen on here is 40 IPM so it should hit that. Definitely more torque than a taig needs but so is 270. Like has been said, companies ship them with 200 oz/in motors. If I were building one I'd just use the $33 185 oz/in motors for the X and Y, they are 50v motors so the g540 would get everything out of them. Hoss
(It just showed up today, so I am pretty excited) 1 G540 4 axis driver 3 KL23H256-21-8B 185 oz. Steppers 1 KL-350-48 48V/7.3A Power Supply 1 E-Stop |
#10
| I would probably go with a 318 for the Z to help with that big spindle motor.
#12
| Without any weight on my table I was able to get 120 IPM on the X and Y of my Taig. I put a 65 pound block of metal on there which forced me to reduce the speed to about 65 IPM. This is with Keling KL23H276-30-8B steppers (bipolar parallel), Gecko 203Vs, with a 40v PSU. |
| Using steppers for something else | ChristianW | DIY-CNC Router Table Machines | 1 | 07-20-2007 03:05 AM |
| do steppers go bad? | gopher | Stepper Motors and Drives | 5 | 07-04-2007 01:01 PM |
| Are these steppers ok? | ghettoblaster | Mechanical Calculations/Engineering Design | 3 | 09-25-2006 12:03 PM |
| STEPPERS Will Someone Please Help!!! | bill south | Stepper Motors and Drives | 5 | 08-29-2006 07:55 AM |
| What about these steppers? | blfinche | DIY-CNC Router Table Machines | 5 | 08-25-2006 12:56 PM |
