Results 1 to 5 of 5
Thread: Cutting Stamps / Blocks
    Feb 2009
    Has anyone here used their benchtop mill for cutting rubber or linoleum for stamps or block printing?
    Dec 2008
    Quote Originally Posted by 5artist5 View Post
    Rubber can be tough to cut cleanly. Many times rubber will actually be ground to final tolerance. Perhaps you might try instead to cut a mold, pour your rubber into the mold and go from there. Cutting the mold in wax will be fast as it cuts quickly, and it's self releasing from a lot of things.
    Nov 2003
    Pennsylvania
    Like teh previous post, rubber is best if it is a shear type cut only. If you are trying to shape it in different forms you are in for some problems. Harder durometer rubber may be easier to cut but harder to work with in an end product. It may also tear or snag in chunks. Best to form moulds of your patterns and work with them from there.
    I might make a suggestion of using silicone to make your stamps if you have to make a bunch of them. You can make teh pattern in clay then form the stamp in silicone or make a reverse-type mould (positive to negative to positive). Silicone is relatively cheap in 2 part mixes. A harder durometer will remain stiffer but you may need to add a backing.
    Feb 2009
    Ok, i like the silicone mold idea.
    What about linoleum?
    Jun 2012
    Nice conversation. Thanks
    Order Stamps Online
    1. Need to make some stamps. Recommendations for material
      By laka in forum General Metalwork Discussion
      Last Post: 01-18-2009, 03:41 PM
    2. end blocks
      By john86126 in forum Linear and Rotary Motion
      Last Post: 04-28-2008, 09:57 PM
    3. MDI ONLY 10 BLOCKS HELP!!!!!!
      By john-shipman@ho in forum 5T/5M
      Last Post: 12-25-2007, 12:34 PM
    4. Question about Raised 3d Lettering Stamps
      By ROBTRONIX in forum General CAM Discussion
      Last Post: 09-11-2006, 11:47 AM
    5. Stamps
      By dighsx in forum Vectric
      Last Post: 05-14-2006, 01:41 PM
