Page 1 of 3 123 LastLast
Results 1 to 12 of 29
Thread: Parker vs. Gecko
    Feb 2009
    Question Parker vs. Gecko
    Getting frustrated with HobbyCNC board and Ebay used garbage.
    I'm ready to buy either Gecko drive or Parker (OFS 350-DRI) but I want to keep my HobbyCNC motors (#23-205-DS8). Can somebody advise which drive is better and if it'll work with those motors.
    Thank You
    Jul 2005
    Those motors are 3A rated at 285 ozin in biplolar. They would run well with either the Gecko 540 unit with a 48V power supply or the G251 individual drives. Larger Geckos on those drive would be over kill. You should see a lot better perfomance with the Gecko. The whole g540 (4 axis) only costs $299.00. The G251 would be more but offers more flexibility.
    TOM CAUDLE
    www.CandCNC.com
    Totally Modular CNC Electronics
    Jul 2007
    My HobbyCNC board is still sitting on my desk. Supported by users but nothing from "factory", never got it working and I am an EE.
    Bought Gecko's and have been running them since with no problems. Using the HobbyCNC motors and their power supply.
    Tons of support from Gecko, not that I have ever needed it.
    There is a reason HobbyCNC only lets you into their forum AFTER you buy.
    Sep 2005
    Indonesia
    Do you think Hobbycnc and Kellinginc have the same brand motor.
    Jul 2007
    no idea. I doubt that my system is finely tuned re motor and drivers.
    I know that Kellinginc has motors specifically for the Gecko drives, but I had the others and so I use them. for what I do (CNC lathe) they work fine
    Registered Chris D's Avatar
    Apr 2005
    I have a HobbyCNC board which is the first board I used for CNC since I started tinkering in this hobby. It assembled fine and easy and works fine to this day. Not being an electrical engineer, or even someone that has a high level of electronic understanding, I guess that should say something for the HobbyCNC product!
    As for Parker or Gecko - obviously a step up in quality, performance, and price. Sometimes you pay more and you get more in return. I have Geckos on two different machines. I have the 203s on a lathe and the new, little 251s on a small desktop mill I have been tinkering with. Both drives serve me well from Gecko.
    Parker is solidly in the industrial markeplace - you willl see parker drives (and other products) in MANY industrial machines. I have not used their drives, but many of thier other products and generally speaking they are good products.
    Chris
    Registered Crevice Reamer's Avatar
    Mar 2008
    Hi Will. Welcome to the Zone!
    Those motors are electrical similar to (And probably are) the Keling KL23H276-30-8B.
    http://kelinginc.net/KL23H276-30-8B.pdf
    I wouldn't BUY these motors for this, but they will run okay with a G540. These motors are rated in UNIPOLAR for 3A 2.2 mH. Wired Bipolar Parallel (as they SHOULD be) they draw 4.2A. With a 48V PSU, they will deliver 237 Oz in of torque when derated to 3.5A.
    Definitely go with the G540, it will run your motors faster than anything but a Gecko can.
    $299 G540
    $060 One KL-350-48 48V/7.3A power supply.
    $010 Estop switch
    $007 3 Home switches
    $009 Straight thru parallel computer cable.
    $385
    All available from Keling:
    CR.
    Registered thkoutsidthebox's Avatar
    Nov 2006
    Ireland
    I started with a HobbyCNC kit and had great support. I'm intending to move to Geckos for my next build, but am not familiar with Parker.
    If anyone has trouble with their HobbyCNC kit, try following this thread to go through it step by step. MY HobbyCNCPro Package Step by Step
    Jul 2007
    I am sure the HobbyCNC parts, design, and material are top notch.
    The problem I had was lack of support when things don't go correctly.
    With HobbyCNC I received one response from the "factory" people "you burned it out". I did get great support from other customers on the forum.
    After switching to Gecko I burned one out with a chip falling onto the driver. I emailed Gecko and they said send it in and they would try and fix it. No luck, totaled.
    They sent me a brand new one, NO CHARGE, as a one time oops.
    Now that is customer service!
    The choice is yours. If you build it and it works first time, you have saved some money. If you have problems and can't get it working you have a brick and wasted money.
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    i would agree with using gecko but i would suggest getting the 201 202 203v , the difference in money compared to the smaller driver is there but nothing too big , it will be something that you will always have ,it will give you the freedom to run larger motors and not be confined to using low amp motors or have to shelf some drivers if or when you upgrade
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    May 2007
    Quote Originally Posted by PoolQ View Post
    What specifically went wrong? I'd think you'd have to do something pretty bad to fry the whole board beyond repair. Worst case is usually that you cook one axis and have to replace $20-$30 of parts, not the whole thing.
    Feb 2009
    I got hobby CNC board 4+ years ago and put it together despite some things being mislabeled the board worked fine with 80ozin motors but I needed beefier motors. So I have ordered 200+ oz in motors and hoked them up. The chips crackled and smoked. I thought that I lacked heat sinks so I have ordered new chips and made heat sinks. I have replaced chips (no easy task) and ran one motor at a time which worked, as so as hooked up all 3- the same effect pops and smoke. So I'm done with being an electrician. My machine mechanically is being complete for 4 years. Right now I just need to get something out of the box so I can work the machine even if it's a bit more $ then HobbyCNC Save myself time, headache, and no more soldering iron.
  • Page 1 of 3 123 LastLast
    1. Parker Metalworking
      By tmechanic in forum General Waterjet
      Last Post: 10-16-2008, 09:37 PM
    2. Does anyone know the Parker ZX600 Series
      By Stang6T8Coupe in forum Servo Motors and Drives
      Last Post: 10-03-2008, 02:15 PM
    3. parker quick couplings
      By spider in forum Moldmaking
      Last Post: 08-31-2007, 11:00 AM
    4. PARKER 6K2 or 6K4 Motion controller
      By TUCSONCNC in forum Post Processors for MC
      Last Post: 02-02-2007, 01:07 AM
    5. Galil, Parker, Allen-Bradley, Gecko, Rutex
      By Tywash in forum Servo Motors and Drives
      Last Post: 11-16-2006, 04:48 PM
