Ok I measured the deflection off the spindle and while a bit jumpy on the dial it is deflectiong off .01". It appears when looking closely that the motor and spindle itself are the only things moving. Do the spindle bearings require tightening now and then? I got this mill 2nd hand and retro fit
cnc to it myself so I am not intimately aware of all its issues.
Also I tried to cut again this time removing climb milling and cutting CW. Now when the cutter gets to the lower right corner and makes its move to the left the head flexes and stays that way until reaching the top left corner of the pocket. I also finally broke the cutter lol and slowed the feed down to 4 ipm.
So I tried again with a .25" endmill and still encounter the same problem. Although it does not appear that the column or saddle are moving at all. It is almost as if the spindle is loose in the headstock but if that were the case it would happen in all directions I would assume.
I am just getting the idea that this little mill has to take super light cuts to avoid these deflections and loosing steps. Man I can't wait till my daughter gets off my dime and out of college so I can get some real heavy equipment. This maybe the hobbiest idea of milling but I find it frustrating as all hell. You finally get one little issue resolved to only find another and another and in the end you still only have this little mill. I want to make parts not watch them being made countless hours or trying to figure out how to mod the mill to make it work right. I guess hobbiest like tinkering with the machine itself as much as cutting parts but man I would really like to just cut some parts and not worry with the rest
Have to hand it to those that can sit there for hours turning those little handwheels making those tiny cuts they have more patience than I do.
Bo
