Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Electrical Enclosure and Wiring.. HELP!
    Jan 2009
    Hello all, I've gotten most of the electronics for my X3 conversion, but I am now trying to figure out what to MOUNT all of this stuff in. I have cadmonkey's plans and he used an industrial electrical box, which would be PERFECT, but I cannot seem to find one anywhere for less than 100 dollars. What is everyone mounting all of their stuff in? Is it best to mount all of your stuff, including the PC in one box, or all the stepper drivers, PSU, etc in one box and the computer in a regular case? I'm looking for any alternatives to the industrial controller boxes, OR a good, reasonably priced place to get one of those.
    IN addition, I'm hung up on stepper motor wiring. It seems people are using all kinds of different things, from expensive Speakon cables, to serial cables, to ham radio cables, microphone cables, etc. What do people recommend? I'd like to keep costs down, including the cost of connectors to mount to the controller box.
    Thanks in advance!
    Oct 2007
    Electrical Enclosures
    I don't know where you live however I use HGR Industrial Surplus in Cleveland, Ohio. Just google HGR Ind. I'm sure there are industrial surplus stores in your area.
    Dec 2008
    I used an enclosure designed for rack mounting. 6" Deep, 3 rack spaces, $60 new. I only put the G540 and 12.5A power supply along with a fan in mine, although you could easily get a bunch more in there.
    I chose to mount the drive electronics on the machine itself, that way the wires from power supply to drives, and drives to steppers were as short as possible. Putting the PC in that environment seemed like a bad idea to me, so I didn't do it that way. I could have crammed all the drives into a PC case with the PC if I wanted, but there seemed little point in doing so.
    Registered SScnc's Avatar
    Jun 2008
    I used a PC tower case for my CNC controls. I think it was about 18 bucks new. I switched from the laptop to a 2.8 Ghz IBM PC. Also have since added a relay board in the CNC PC case for spindle and flood control.
    As for wiring, I use round 16-4 speaker wire.
    HTH
    Attached Thumbnails Attached Thumbnails Electrical Enclosure and Wiring.. HELP!-img_0628.jpg   Electrical Enclosure and Wiring.. HELP!-img_0629.jpg   Electrical Enclosure and Wiring.. HELP!-img_0631.jpg
    Jan 2009
    Thanks everyone for the input so far! I'd like to get more ideas, but I did find some reasonably priced Industrial Control boxes at HGR online.. now to find out how much the shipping will be! Thanks for the info Escott, but I think I'd like to put everything in one enclosure.. if possible and if it wouldn't cause any problems, obviously it would have to be well ventilated.
    I also like your setup SScnc. What type of connectors do you use on that wiring?
    Jul 2007
    Firestorm,
    I just ordered a bunch of 14 & 16 gauge wire in a bunch of different colors from McMaster. However, I had to buy 25ft of each color (smallest amount they would let me order). Perhaps we can split it. I think I ordered blue, red, black, orange, brown, yellow, purple.
    -Caleb105-
    Harbor Freight X3, Keling 387inoz 23's, 640inoz 34, G203V's, Homebuilt 65V PSU, PMDX-122 BOB, NOOK XPR screws, NOOK SBN ballnuts, Shuttle Pro2, Mach3
    Jan 2009
    Caleb105, sounds great for the cabling! That would be great to split that cost. My question however is, what are people using as the actual CONNECTORS...
    Registered cadmonkey's Avatar
    Mar 2006
    For cable to the cables to the steppers I used a 4 conductor 18 gauge cable from Home Depot (forget what it was called, I had a spool of it from a previous job). For connectors I used Ham radio microphone plugs and receptacles - not sure where to get them online, I stop at the Hamfest when it rolls through town each March and get stuff like that there.
    Having everything in one box is nice, but it is hard to find that kind of enclosure reasonably priced. I got mine used from an R&D firm.
    Every day is a learning process, whether you remember yesterday or not is the hard part.
    www.distinctperspectives.com
    Jan 2009
    Sounds great cadmonkey, did you just use regular wire with those ham radio connectors? Do you happen to know what they can handle as far as amperage is concerned? Also how did you mount them to your enclosure, do they have external threads?
    Mar 2006
    Used the cable I mentioned in my last post. Not sure about the max amperage, but they have beefy contact area and haven't had any problem running for a long time sustained on my machine. The receptacles mount just like any other panel mount connector - they are threaded and have a jam nut.
    Registered zephyr9900's Avatar
    Feb 2006
    Quote Originally Posted by cadmonkey
    If you're talking about connectors like the following, lots of places. Radio Shack has them (if you search on "4-pin microphone" on thier website the male and female connectors will be the first two results) and it is one thing where the RS quality is better than the cheap Asian knockoffs I have bought online (better plastic in the insulator and better quality in the locking ring threads) and IMHO worth the extra cost. I've used them for years on all my stepper machines.
    Randy
    Attached Thumbnails Attached Thumbnails Electrical Enclosure and Wiring.. HELP!-mic_connector.jpg
    Jan 2009
    Caleb105, I'm looking at McMaster's site, which speaker wire did you get?
  • Page 1 of 2 12 LastLast
    1. electrical ,electronic
      By shawnmor in forum General Electronics Discussion
      Last Post: 10-18-2007, 07:40 AM
    2. Electrical/Electronics Enclosure
      By audioandy1762 in forum DIY CNC Router Table Machines
      Last Post: 02-27-2007, 07:32 AM
    3. well the electrical part is almost done
      By truman in forum DIY CNC Router Table Machines
      Last Post: 08-13-2006, 12:04 AM
    4. Electrical noise.
      By MrBean in forum General Electronics Discussion
      Last Post: 01-13-2005, 07:25 PM
    5. Electrical Isolation? (p.sup.)
      By FLUTE HEAD in forum General Electronics Discussion
      Last Post: 08-24-2004, 02:55 PM
