Old 02-20-2009, 10:28 AM
caleb105 is on a distinguished road
X3 Base Mounting Hole Distances?
I'd like to build an elevated table for my X3 (which is on backorder). The manual states the maximum working envelope (45" left to right), but I'm looking for the distances (side-side and front-back) of the mounting holes in the base. Thanks!
Oh, and if anyone has Autodesk Inventor files of the X3, that would be sweet!
-Caleb105-
Old 02-20-2009, 11:27 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Originally Posted by caleb105 View Post
I'd like to build an elevated table for my X3 (which is on backorder). The manual states the maximum working envelope (45" left to right), but I'm looking for the distances (side-side and front-back) of the mounting holes in the base. Thanks!-Caleb105-
Distance between holes left to right: 11 7/8"
From facing front of mill:
Left side mounting holes:
Center of rear hole from back of base is 15/16"
Center to center is 14 13/16"
Center of front hole from back is 15 3/4"
Right side mounting holes:
Center of rear hole from back of base is 7/8"
Center to center is 11 1/16"
Center of front hole from back is 11 15/16"
Don't forget to allow clearance on overall measurements for motors & mounts.
If you increase travel on any axis, it will increase that enclosure dimension.
Don't forget there is 5" of column cover BEHIND base.
Do not CENTER the mill. Due to X travel differences L to R, the mill will be offset to the right some.
CR.
Old 02-20-2009, 04:37 PM
CR,
Thanks you SOOOOOO much! That was EXACTLY what I was looking for!
I'm going to be making a stand out of 1.5" x 1.5" Tslot aluminum. I'd like to end up with a full enclosure made out of 1" x 1" Tslot (I've got a bunch sitting around)...so I'll probably make the footprint of the stand something more like 30" deep and 30-45" wide.
I'll try to draw something up so you guys can critique it!
-Caleb105-
Old 02-20-2009, 05:12 PM
Correction: MY mill is offset to right because my stepper mounts on the left. YOURS may vary.
CR.
Old 02-20-2009, 06:57 PM
This is kinda what I'm thinking:
1.5" x 1.5" for most of it, and 1.5" x 3" for the legs. Obviously I'll have some sort of diagonal cross-bracing. Dimensions are about 30" x 46"
Old 02-22-2009, 05:04 PM
No thoughts? You guys can critique anything!
ETA:
I calculate that with this design, I will have the following deflections:
The two 30" supporting beams running front-back that the machine actual bolts to will sag about 1/32" each.
The two 46" beams running left-right will each sag slightly more than 1/8" each.
Taig mill bottom base mounting bolt hole spacing pattern Hirudin Taig Mills & Lathes 4 01-20-2009 03:42 PM
NEWBIE HELP>> How do you input a drill hole or extrude a hole that is.. l u k e Solidworks 9 02-11-2008 11:54 AM
Will X2 column fit on X1L Base? Smertrios Benchtop Machines 1 01-09-2007 04:00 AM
Extending RS232 over long distances jderou General Electronics Discussion 26 11-04-2006 07:23 AM
Can I run BDI-4.08 on Fedora 3 base k-linkz LinuxCNC (formerly EMC2) 1 03-14-2005 01:07 PM
