So....now a few more questions! At least initially, my X3 will be limited to 2000rpm. From what I have read, Aluminum should have a surface cutting speed of 250-350 fpm. If I aim for the low end of this (250fpm), then @ a maximum 2000rpm, aren't I limited to 1/2" or larger end mills? I know that some people have gotten their X3's running at 6000rpm, which would let me go as small as about 5/32" end mill and still maintain 250fpm Surface Cutting Speed. Thanks! -Caleb105- |
Regards, Ray L. |
| Bearing pockets, etc. can be cut using a rotary table or boring head. They can also be done on a lathe. Regards, Ray L. |
Also, the feedrate won't have anything to do with the surface cutting rate. So....are you trying to tell me that people use a 1/4" endmill and are milling their aluminum with 130fpm surface cutting speed? -Caleb105- |
| I know that both the SFPM and IPM are both dependent on RPM. However, they are not directly related to each other. What I am asking is....How are people dealing with lower SFPM? Are they just milling AL at 130fpm and praying that it doesn't gum up their endmills? |
"Are they just milling AL at 130fpm and praying that it doesn't gum up their endmills?" - It's either that, or figure out how to increase spindle RPM. Ain't no other options. Regards, Ray L. |
#11
Meaning that this speed will be a good balance between Toollife and Metal removal rate. In a hobbyshop where cost of Endmills may be rated a little higher and manhours a little lower it can make perfect sense to derate the SFPM. The longest Toollife may be well below of the manufacturers recommended SFPM. |
#12
| I'm regularly using 1/32" endmills on my x3, and while it does take for ever to run a complete job, it does work, and i dont have any gumming issues... good flood coolant is my thinking as to why i have been getting away with it...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
| Need Help!- Advice for cutting .002" shim stock w/ endmill | stipierreinc | General Metal Working Machines | 9 | 01-29-2009 10:19 AM |
| 1/8" shank endmill holder | CNCMike | General Metalwork Discussion | 7 | 10-23-2008 11:58 PM |
| 3/4 endmill, 4" necked back | rbest27 | General Metalwork Discussion | 2 | 01-30-2008 12:59 PM |
| Slotting Titanium 3/16" Endmill | TZ250 | General Metalwork Discussion | 6 | 12-10-2007 06:21 AM |
| Sqealing .75" 6 flute endmill | jderou | General Metal Working Machines | 3 | 03-13-2006 08:48 AM |
