| Steppers for Gecko 540 I'm trying to figure out exactly what setup I am going with for my stepper motors, controllers, BOB and psu. I had decided that I want to go with 387 in oz. nema 23's for the x and y and a 640 in oz. nema 34 for the z. Operating voltage on the 23's should be around 64V and about 45V for the 34 assuming that I wire them parallel. I was planning on building a 45V psu and underpower the 23's a little. THEN, I discovered the Gecko 540, a sweet little deal with 4 controllers and a BOB all built in. BUT, there's a catch, it only accepts up to 3.5 amps and 50V. I'm looking out there and i cannot find an acceptable stepper for the z axis that runs at 3.5 amps or under unless I wire it in series, in which case now my operating voltage goes WAY up to around 95 volts! Does ANYONE know of a good combo that will work with this sweet little Gecko unit?! |
| Here are a couple of websites that have some motors that will work well with the G540: www.kelinginc.net www.homeshopcnc.com www.camtronics-cnc.com If you have any questions you can shoot me an email through our support page at www.geckodrive.com or give us a call at (714) 832-8874 and we can help you out. Marcus Freimanis |
| G540 set ups here's a specific link for Keling that you may find helpful. http://www.kelinginc.net/CNCNEMA23G540Package.html My research has concluded that the "wise ones" agree.... there is no NEMA 34 motor available that will run optimally with the G540. I decided that I wanted to go with the G540 anyways, and being able to pick one of their special run over stock units up for $225 sealed the deal for me. I'm going to run all three axis with Kelings KL23H284-35-4B 387 oz-in NEMA 23s. I figure that I can get the mechanical advantage I need with a drive belt setup and live with a slow z (if indeed it is slow) Electrical theory is the weekest link in my knowledge base, so having a no brainer hook up with certainty about the compatability of the components made that little G540 the winner for me. The prospect of farting around for months trying to set up a control cab. was a big turn off. |
| Thanks for the input, I definitely see where you are coming from, but I have decided I am definitely going with a Nema 34 for the Z. I NEED to make sure I have enough power there. I found a Nema 34 600 in oz. that has an optimal voltage of 70v if wired in series at 3.3 amps. If my understanding is correct, i will still have all the power from the motor because I will be running it at full amperage, but I will just get 69% of the top speed out of it with a 48v psu. Losing a little speed is ok with me, but being underpowered is not. I AM really interested to find out where you got your gecko for 225 though! |
| These were the ones going at $225. Unfortunately, there was a posting today advising that sale has finished as the overstock was all gone. [I got mine ]
__________________ Regards Geoff |
| Need Help!- Want Gecko Drives for Steppers but Need Help | wganders | Gecko Drives | 6 | 12-04-2008 08:16 PM |
| wiring steppers/ gecko 201 | littlebear | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-08-2006 11:26 AM |
| Help-2 steppers/one gecko drive | Jersey | Gecko Drives | 2 | 05-12-2006 01:57 AM |
| X axis - 2 steppers 1 gecko ? | andy_ck87028 | Gecko Drives | 3 | 11-17-2005 03:50 PM |
| Gecko 201 for my steppers? | snaggletto | Gecko Drives | 0 | 02-27-2004 11:22 PM |
