Old 02-14-2009, 05:49 PM
caleb105 is on a distinguished road
Which Breakout Board?
Help me, oh might CNCzone! Grant thee a sliver of thy eternal wisdom.
I am doing an X3 with Nema 23's on X,Y, and Nema 34 on Z. I don't know if it matters, but I'd like to add an MPG (Manual Pulse Generator) in the future as well. Oh, and possibly a 4th axis.
Nema 23's = 387 in-oz 3.5A, 65volt
Nema 34 = 640 in-oz 3.5A, 65 volt
PSU = 65volt/20A (DIY type)
G203V's
Thanks!
Old 02-14-2009, 05:58 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I think just about any BOB will work. Depends on your needs and how much you want to spend.
I am using C10 BOB's from CNC4PC and I'm happy with both cost and function.
Lee
Old 02-14-2009, 06:12 PM
Leeway,
Yes, I have been looking at cnc4pc.com also. Do you need a C10 BOB for EACH motor?
Thanks!
-Caleb105-
Old 02-14-2009, 07:18 PM
LeeWay's Avatar
No. The single C10 BOB does all four axes. Take a look at the schematics for each BOB you are looking at. Most BOB's will handle 4 axes. Pins 2 thru 9 are generally step and direction pins. One of each per axis.
A BOB mainly breaks out all 25 pins on a parallel port. Many do more than that, but that is a basic BOB.
Lee
Old 02-14-2009, 07:21 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Hey Caleb,
An MPG only needs 2 inputs and power so you could use one on a single C10 along with 4 motors.
If you want to have a manual axis selector switch like is used on cnc4pc's pendant
you'll need another C10 to handle all the OEM trigger inputs (10 on mine).
You'll also have to get the Mach 3 Brain to process the signals.( cnc4pc gives one for 4 axis)
A switch is more convenient than jumping back and forth from the MPG and mouse.
An easier tool might be the Shuttle Xpress or Shuttle Pro, I'm going to use one for my new build.
They've been on Ebay for $45.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 02-14-2009, 08:30 PM
Lee, thanks for the BOB info.
and Hoss, thanks for the great info on the MPG's. That shuttle express looks pretty interesting.
So my big question is, which of the following would you recommend? Seems like there are tons of different models, with greatly varying prices, and I really don't understand all the differences between them:
C1
C1G
C10
C11
C11G
C11T
C23
C25 (smooth stepper?)
KL-DB25
What is the "Smooth Stepper"? Keling's got one, but it's $159!! What the heck does this do? And is it necessary?
Old 02-14-2009, 08:49 PM
From a different thread:
Originally Posted by HimyKabibble View Post
On the BOB, the only one I don't think I've ever heard a single complaint about is the PMDX. I've personally had, and continue to have, frustrating problems with my CNC4PC C11 BOB (I'm on my third revision now).
Regards,
Ray L.
Old 02-14-2009, 08:59 PM
hoss2006's Avatar
The C10 is a simple breakout board, I haven't had a bit of trouble with either one I use.
the other multifunction boards like the c11, c23 have extra features like relays, speed controls etc with some gecco specific.
I like to keep things separate, less complexity to go wrong.
the smooth stepper is a USB driver, his c25 is just a breakout board for it.
Old 02-14-2009, 10:18 PM
So....looks like my choices are:
C10 = $25.49
PMDX 122 = $81
Is there any reason to spend the extra money on the PMDX? Seems like both the C10 and PMDX are reliable.
Old 02-14-2009, 10:38 PM
hoss2006's Avatar
The PMDX has a charge pump on board the C10 doesn't.
the C4 is $22.
  #11   Ban this user!
Old 02-14-2009, 10:40 PM
HimyKabibble is on a distinguished road
C10 = $25.49
PMDX 122 = $81
The advantage is, if you accidentally short something, with the PMDX you'll most likely just blow up a chip on the PMDX. With the C10, you'll likely blow up the parallel port on your PC, or worse. Isolation is worthwhile. Most people will never *need* it, but it's cheap insurance.
Also, if your PC has a low-voltage parallel port, the PMDX will work fine, where the C10 might, or might not. This can cause flaky problems that can be very tricky to track down. Or the current capability of the parallel port may be marginal, and one day you'll hook up one more signal, and start getting flaky behavior. The PMDX runs from a separate power supply, so this will never be an issue.
Regards,
Ray L.
  #12   Ban this user!
Old 02-14-2009, 10:44 PM
the C4 is $22.
C4?
On the CNC 4 PC breakout board seanreit General Metal Working Machines 8 11-30-2008 04:10 AM
what USB Breakout Board to by ?? dbss General Electronics Discussion 5 01-19-2008 08:54 AM
Is necessary to use a breakout board? rolveram Stepper Motors and Drives 15 08-28-2007 11:28 AM
Breakout board, Relays on board? Cooper Open Source Controller Boards 11 06-09-2007 08:55 PM
Breakout Board bkkpool General Electronics Discussion 2 07-28-2006 02:15 PM
