#25
| If Mach 3 had more support for USB chips made by http://www.ftdichip.com/ then USB would be easier to implement, and we wouldn't even have to worry about this type of problem in the first place. |
#26
| On another thought, there is no reason to have opto isolation before a relay either. I mean think about it, you already have isolation because the relay uses a small signal to charge a coil, which is isolated from the higher voltage by magnetism instead of light in opto isolation. So people who shell out extra for these boards that have opto isolation are really just throwing their money away on redundancy. |
#27
Regards, Ray L. |
#28
So you're worried about a little 5V signal from a switch messing up your computer? Interesting. I would think most people aren't using their brand new top of the line computers that they just bought for their milling work anyway, so all this talk about how it's going to destroy your computer is pointless when used computers are practically through away these days. |
#29
You could also have an accidental short in your motor drivers or power supply that ties your 5V bus to your 70V motor supply - S**t happens. Or short an AC line to a signal line. Anything like that will wipe out pretty much anything in it's path, up to the optos. Your PC will be spared. The whole idea is to protect against unplanned events, which DO occur, at least to the rest of us. Opto isolation is insurance. Most people will never need it, but if you do, it's really nice to have it there. For me, it's a good trade-off. For you, perhaps not, but that's no reason to dismiss the entire concept. It's VERY widely used in industrial machines, and for good reason. Regards, Ray L. |
#31
#32
| Step & Dir into the Geckos are isolated with high speed (2 mhz) optos. (except for the 250 series). The buffering on a BOB is to improve the noise immunity of the parallel port. The outputs of a PP are logic level MOS. The pins are not designed to source over a few mills or sink more than about 10ma. The challenge of moving signals across cables over distance is that the higher the driving impedance the better antenna it makes. If you give some attention to proper design and buffer the step & dir signals you can clean them up, logic shift to full 5 V and provide a low impedance drive that will allow the use of 5 meter cables with no problems. The world of industrial electronics is a lot more challenging than logic control. Running logic level signals mixed in with high current PWM and other sources of EMI requires an understanding of grounding, isolation. shielding and differential signaling techniques that honestly baffles even some Electrical Enginners. The opto isolation of inputs breaks ground loops, conducted noise and potentially destructive voltages. To be truly isolated the two circuits must NOT share the same ground (E.g. separate Power Supplies with separate common (grounds). Inputs can typically be a lot slower than is needed for the step & dir signals. All of our cards from day one have had full buffering on all step & dir, Double buffering on relay outputs and opto isolation on all inputs. We have always offered a dual power supply to drive the cards to give the isolated input power. You can get by with ignoring the rules on smaller systems or where three is only one machine in the mix and distances are short. Toss in something like plamsa cutting or other machines and the gremlins of EMI and RFI will make you pay. Maybe some other motor drives with straight TTL inputs need external isolation but it needs to be the right kind. Conventional optos have poor bandwidth. High speed optos are readily available but $$ compared to lower speed. Proper documentation is always important. You should not have to take night courses in electronics to build a CNC machine! TOM CAUDLE www.CandCNC.com Totally Modular CNC Electronics Universal Breakout Board manual at www.CandCNC.com/PDF/UBOB_Manual.pdf |
#33
I'll change my opinion to simple hobby CNC mills like the X3 don't need any more isolation other then which is provided by the geckos and relays. As Torchhead points out, good isolation does have it’s place though. |
#34
| I always get a kick out of this search for super isolation. I developed a personal strategy many years ago that although in the use of isolation components such as SSR and interfaces such as OPTO offer, I still referenced all the different systems to Earth ground, which essentially ends up at some point, to each other, including the PC power supply. Looking through my records, I first started installing PC based systems in the late 1980's. This has been in some the harshest industrial environments imaginable. These systems are still successfully in operation today. Also I did not succumb to the credo that 'You must use a Industrial PC', I figured for $8,000 I could get alot of metalwork done. The answer to the question on whether to isolate or not is personal preference, but the bottom line is, either method has to be done with due diligence. I believe that many of the sellers of BOB's, stress the isolation method as it may be easier for many of those that use their product, may not have a background or experience to implement a uni-potential bonding system. Some of the regular complaints of spurious switch trips etc, I swear are due to not adopting the common ground method. Al.
| On the CNC 4 PC breakout board | seanreit | General Metal Working Machines | 8 | 11-30-2008 03:10 AM |
| what USB Breakout Board to by ?? | dbss | General Electronics Discussion | 5 | 01-19-2008 07:54 AM |
| Is necessary to use a breakout board? | rolveram | Stepper Motors and Drives | 15 | 08-28-2007 10:28 AM |
| Breakout board, Relays on board? | Cooper | Open Source Controller Boards | 11 | 06-09-2007 07:55 PM |
| Breakout Board | bkkpool | General Electronics Discussion | 2 | 07-28-2006 01:15 PM |
