Old 02-13-2009, 03:06 AM
cowcowlee is on a distinguished road
Sieg KX3 Rigidity
Hello
Anybody own the sieg KX3 here?? I have found my one the head stock got a lot of flex (0.1mm) even push and pull with my hands side by side (I'm not a Muscle guy), I suspect it cause by the weak vertical column, it caused a lot of chatter when I tried use the 10mm endmill cutting with 6061 even only 3mm depth.
Kral
Old 02-13-2009, 08:37 AM
scudzuki is on a distinguished road
Are the gibs properly adjusted?
Joe
Old 02-13-2009, 10:38 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
I'm pretty sure that's the same column as my SX3. Properly braced, the X3 column is VERY rigid.
CR.
Old 02-13-2009, 10:42 AM
ihavenofish is on a distinguished road
yes, make sure the gibs are tightened and the ball screw bearings also tight. there will always be some degree of flex on every machine, but i think this one should be a bit better than .004" with just light hand force (30-40lbs).
for the gibs, youll have to pull up on the head somehow. an easy way is by resting the spindle nose on a block of wood. then youll find you can tighten them significantly better than if the spindle is just hanging normally.
Old 02-13-2009, 12:15 PM
I'm sure the gib is well adjusted, also I read some elder post talked about this issue, the back side of the head stock near the vertical column just got about 0.01mm when I push it, however it comes 0.1mm near the spindle (caused by the lever effect), it makes the cutter bounce a lot even with the shallow cut. Just not sure it caused by the gap from dovetail or flex of the column, will take more measurement tomorrow.
Kral
Old 02-13-2009, 12:19 PM
Originally Posted by cowcowlee View Post
I'm sure the gib is well adjusted, also I read some elder post talked about this issue, the back side of the head stock near the vertical column just got about 0.01mm when I push it, however it comes 0.1mm near the spindle (caused by the lever effect), it makes the cutter brounce a lot even with the shallow cut. Just not sure it caused by the gap from dovetail or flex of the column, will take more measurement tomorrow.
Kral
that sounds alot like a loose gib. it could be flex, but its alot easier to rule everything "simple" out first.
Old 02-13-2009, 04:01 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
CR.
holy sh!t, your a master fabricator!
Old 02-13-2009, 04:21 PM
ataxy's Avatar
ataxy is on a distinguished road
id like to see more picture of the brace if possible
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 02-14-2009, 08:13 AM
My goal with this was to have a lightweight yet very rigid CNC industrial-duty milling station. The braces are part of the flood cooling enclosure framework. The mill is easily accessable from all sides--including underneath the base.
CR.
Old 02-15-2009, 03:43 PM
Eson's Avatar
Eson is on a distinguished road
Try and lower the head till it rest on a piece of stock and then tighten the gibs.
The weight of the head can jam the gibs.
  #11   Ban this user!
Old 02-16-2009, 09:24 PM
ok....I did some more measurement on the vertical column yesterday, it's really flex, especially much more easy to lean forword/backward then the left/right, that's why the much more chatter when milling in Y direction rather then the X direction I have experienced before, however still don't know the root cause, most of the possibility is the column's base plate since it's only locked down by 4 bolts, it may twist or life up on the edge while the force applied on the column.
  #12   Ban this user!
Old 02-16-2009, 10:12 PM
have you tightened the Z gib yet? thats really where you need to start. without checking that 100% youll never be able to track down the issue.
the column will have a little flex for sure. so will the head. so will the tool, etc. there might be a little play in the Z ball screw breaing mounts.
you need to go systematically through each one to find out which is the biggest cause of flex, fixing them along the way if possible.
my little kx1 had loose z gibs, and play in the ball screw mount on both the z and y. when i tightened it all up, there was virtually no meaningful flex left without exerting more pressure than the machine sees while running.
X3 column rigidity? lagfish Benchtop Machines 55 12-22-2008 10:51 PM
Milling rigidity question pminmo General Metalwork Discussion 12 05-30-2008 02:29 PM
Tormach Rigidity keen Tormach PCNC 2 08-09-2007 08:15 PM
Locking Quill & Splines for Rigidity BobWarfield General Metalwork Discussion 0 08-07-2006 04:08 PM
machine rigidity frankv Mechanical Calculations/Engineering Design 10 05-11-2005 08:30 AM
