  #13   Ban this user!
Old 02-17-2009, 01:58 PM
ihavenofish is on a distinguished road
Originally Posted by project5k View Post
you know, i've allways wondered how you hold a stone in like that.. is it inserted from the bottom and then has tabs under it, or is it glued in place?
could heat the ring to expand the hole then set the stone and let it cool. only need a fraction of a mm expension to get an interference fit on the jem.
thats how id do it anyway :P
  #14   Ban this user!
Old 02-17-2009, 02:16 PM
project5k's Avatar
project5k is on a distinguished road
hadn't thought about that. makes sence, i do it when i wanna press fit a bearing onto something.. i warm the bearing gentley with a big hot light, and i freeze the part and they just slip together, but once they both get back to room temp, you cant budge em.
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Need Help!- Has anyone cut 13-8 stainless crazymat14 General Metalwork Discussion 8 04-12-2011 05:11 PM
Need A Quote- RFQ: Small (3"x5"x1/2") part from dimensioned drawings in Aluminum or stainless octathorpe Employment Opportunity 6 06-23-2008 07:14 PM
304 stainless fourperf Haas Mills 6 02-07-2008 08:49 PM
small stainless parts fastolds Employment Opportunity 3 03-09-2007 09:02 AM
Stainless 304 pauls General Metalwork Discussion 11 06-04-2005 03:50 AM
