| conversion factor.... can some one please share the conversion factor to get from N-cm to oz-in and yes... I'm being lazy, as all my good references are in a box in the attic. Matt |
| Matt, Try google. In the search box type " 5 inches in cm" and it will give you the length in cm. I'm sure it'll do torque also. Actually it's amazing what it'll do. ![]() Cheers, |
| Multiply Nm by 141. That gets you pretty close. 141.6 is even closer. CR. |
| Oh! You wanted N cm? Multiply N cm by 1.416. CR. |
| As Kalvin mentioned, Google will do most conversions but for some reason "## newton centimeters to ounce force inch" doesn't work. Can anyone figure out the correct terminology? Until then here's a good calculator... http://www.magtrol.com/support/torque_calc.htm Note: I'm not sure about other browsers, but if you're using Google Chrome you must hit the "Convert" button as hitting the <enter> key will just clear the form. This site actually has a few calculators, click below for more... http://www.magtrol.com/support/calculators.htm |
| http://www.onlineconversion.com/ Save this as a bookmark or shortcut. http://www.onlineconversion.com/torque.htm 1 newton centimeter = 1.416 119 322 8 ounce inch Last edited by Dorsal; 02-07-2009 at 04:45 PM. Reason: more data |
| how do i calculate the K-FACTOR in sheet metal | joe_k | Mechanical Calculations/Engineering Design | 6 | 12-13-2011 11:09 AM |
| Shrinkage Factor for Investment Castings | Tazzer | Casting Metals | 0 | 09-09-2008 05:09 PM |
| servo conversion vs stepper conversion | contractdesign | Bridgeport and Hardinge Mills | 3 | 07-26-2008 03:54 PM |
| Incompatibility of Power Factor Correction Capacitors with AC PWM Drives | kreutz | General Electronics Discussion | 0 | 06-04-2008 10:56 AM |
