Old 12-11-2004, 06:16 PM
rustyolddo is on a distinguished road
Mini Mill 5/8 Ball Screw conversion Question
Converting my mini-mill to ball 5/8 ball screws. The Y axis is easy. I recall someone doing their X-axis and having to remove some material from the saddle and/or the underside of the table. I believe there were some pics posted somewhere but I cannot find them. Was wondering if someone had a pic or details showing the material removed to accomodate the X-axis ballnut. Tnx.
Old 12-11-2004, 08:06 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Here is my conversion thread- http://www.cnczone.com/forums/showth...ght=micro+mark
I don't know how much I removed, but you just need to mill out the bottom of the bed until the assembly will clear.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 12-11-2004, 09:29 PM
Looking at the saddle, a portion of it where the bronze nut is must be removed as well to allow clearance. Do you have a ballpark guess as to how much you removed under the table?
Saw your Ball screw & nut reference in the other post, are the preloaded ballnuts longer or larger? Did you use those or the std. ballnuts?
Your conversion looks nice, I'm using Ron Steeles plans and I'm just about finished. I wanted to conver the x/y to ball screws and add the brass gibs while I was there. Also want to add the limit switches. Thanks for the help.
Old 12-12-2004, 12:24 AM
Gold Member
JFettig is on a distinguished road
Remember to mill the slots that you lock your ballnuts to squair, I beleve they have a slight angle on them so that when you tighten the leadnut down it eliminates some backlash, it causes the ballnuts to bind, for me at least it did, I think my ballnuts are rather shot because of running it like that, i have like .008 backlash in x and y.
Jon
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Mini Mill Conversion Question jjwl89 Benchtop Machines 15 12-25-2005 04:01 PM
Ball Screw Mounting Question. Willyb General Metal Working Machines 11 01-18-2005 12:02 PM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 08:37 PM
possible cnc conversion on homier mini mill WsW-WYATT Benchtop Machines 3 03-27-2004 07:24 AM
