02-19-2009, 06:31 PM
Originally Posted by caleb105 Well, I went ahead and ordered one of those 5" Enco vises also. We'll see what the accuracy is. It should be good enough to start with (i.e. machine my CNC parts). Well I was at it, I ordered the 20 endmill set with TiN coating, set of 10 thin parallels, and the 11 piece Collet set. Total = $200.84 with free shipping.
I did end up ordering SOME of the stuff from LMS that would have been in the X3 kit. I picked up the Clamping kit (7/16") for $40, an edge finder, dial indicator, magnetic base, vise clamping kit, micrometer, 1-2-3 blocks. Total with shipping = $203.11 ....I shudder to think what the shipping WOULD have been on that vise!
So.....will these endmills work for Al? Do I need to keep ferrous endmills away from non-ferrous ones? I know that 2 flute is better for Al.
Damn....who knew this hobby would be so expensive! I've burned through about $2200 in the past 2 weeks!
-Caleb105- |
Personally I've found TiN coated endmills to be a bad idea for aluminum. I always get a lot of chip welding. I'd second the recommendation on getting good endmills, as they certainly are worth it. HSS is fine, especially for aluminum, no coating needed. There is a lot of hype around different tool treatments and everyones "secret recipe". True advantages (if any) for these tools come at much higher speed/feed/production rates on bigger, more rigid machines. Learn to make uncoated HSS work, then move on IF you need to. |
