#13
| Gary |
#14
| Regards, Ray L. |
#15
| Thanks again for all the info. I ordered some hall effect switches to try out. I really like the idea of them being so swarth resistant from the sound of it. My home switches are currently wired normally closed as is rcomended. This bit me a couple times recently after installing the flood coolant and not properly protecting the switches. Bad sounds when the switch stay closed while homing:-) Thanks again for the help so far! Mark [mkenney] |
#16
Mark [mkenney] |
#17
| I posted this question over in this forum: http://www.cnczone.com/forums/showth...846#post541846 I'm trying this setup and struggling so far. I have the same sensor's and swear I thought I have things wired correctly, apperently not. I have +5v going to pin 1 (VDD), pin 2 to the input on the break out board and pin 3 goes to the ground. I have a 1k resitor between the +5v and the input on the breakout board. I wave different magnets different ways and get nothing. What am I doing wrong, been one of those days? |
#18
| I assume you're not really using application circuit 12.1 just what you have listed above correct? I would wire up the circuit in 12.1 exactly, hooking grounds to the ground on the BOB and the Vcc to the 5V on the BOB. Before hooking up the Vout to the BOB, do you have a multimeter or better yet a scope? Personally I test on a breadboard on the bench (electronics, not machining) before it goes near the controller.
__________________ Every day is a learning process, whether you remember yesterday or not is the hard part. www.distinctperspectives.com |
#19
| this is something that i should really put some time into on my machine, as it sits now i have no limit switches, or home switches or anythg.. i have some of the little roller switches, but running full flood coolant makes me worrie about them... I have a pile of home door and window alarm magnetic contatcs, i wonder if i could use thoes, cause i can seal them up, and then i dont have to worrie about the coolant getting in them... one other thing to think about, if your using any kind of magnetic switching, watch your ferrous swarf.. it could build up on the magnets and cause problems...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
#20
Thanks for the help! Mark [mkenney] |
#21
Regards, Ray L. |
#22
| Mark [mkenney] |
| PROXIMITY SWITCH ? | Chappyd | Hyundai Kia machine | 2 | 01-14-2009 07:25 PM |
| New Machine Build- limit switches -proximity sensor vs optical | circlecn | Benchtop Machines | 1 | 09-11-2008 11:10 AM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
