  #49   Ban this user!
Old 02-17-2009, 05:03 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
CORRECTION TO PREVIOUS POST. I made a typo. The resistors solder into the DB-9 connectors NOT the DB-25.
You will need THESE 1/4 Watt 3.48K resistors for the 387:
3.48KXBK-ND
and THESE 1/4 W 2.8K resistors for the 270s:
2.80KXBK-ND
They only come in a pack of five, so about $1.
http://digikey.com/
what switches do you have now?
CR.
  #50   Ban this user!
Old 02-17-2009, 08:05 PM
CNC74 is on a distinguished road
Switches
CR,
The switches from this auction are the ones I have now. (quantity of 6)
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260360389286
"CNC Limit Switches for stepper motor systems N. O."
And do I need the relays you mentioned on page 2 of this post?
Regards,
  #51   Ban this user!
Old 02-17-2009, 08:37 PM
I used 3 of those switches for home switches. It's more complicated, but those NO switches CAN be used as limit switches. I like to use NC limits and wire them in series as in the drawing. Enco has some simulated roller switches that cost about $3 each and can be wired either Normally Open or Normally Closed.
You COULD, since you're using stepper motors not servo motors, even forego the limit switches entirely and just set up the Mach3 software limits.
http://syilamerica.com/docs/Homing_V...%20Limits.html
Relays are handy if you want to have the computer do things from inside the program like turn the spindle on or off, or control a pump for flood coolant.
CR.
Laser guide to setup parts DennisCNC DIY-CNC Router Table Machines 10 06-07-2009 06:29 PM
CNC Prices Joshrichard CNC Machining Centers 1 09-22-2008 10:06 AM
Low prices there... GEORGETOUBALIS CNCzone Club House 0 09-27-2006 06:44 PM
What are you doing about energy prices? Netjams CNCzone Club House 17 05-03-2006 12:50 AM
Parts list for a typical controller setup bgolash Gecko Drives 1 09-20-2004 08:20 AM
