  #61   Ban this user!
Old 02-18-2009, 01:10 PM
cadmonkey's Avatar
cadmonkey is on a distinguished road
I'll have to look in my Nook catalog when I get home late tonight and see if I am remembering correctly - I think metric screws are measured by their root diameter, whereas english by their nominal OD - thus a 12mm and a 5/8 are roughly the same (the root of the 5/8 screw stock is right around 1/2" thus I ground my journals to 10mm for 1mm shoulders at the bearings). I could be wrong (it happens a bit) so don't take that as gospel.
EDIT I was wrong - a 12mm x 2 Nook has a 10.6mm root diam, 12mm x 4 = 9.8mm root diameter. And the root diameter on the Nook 631's is .500"
Sorry - at least I verify my facts...
/EDIT
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
  #62   Ban this user!
Old 02-18-2009, 10:26 PM
Matt McColley is on a distinguished road
Well I painted like a busy beaver tonight.... and have a friend coming over to help paint tomorrow...... and that means..... I'll have fullfilled (mostly) my honey-do pre-req. and can order the mill on Friday
Can anyone tell me if Grizzly ships their X3 mill assembled? Or does it come with the head removed?
If assembled, is the mill sufficiently secured to the base of the crate that I can tilt the crate without having the mill topple over inside the crate?
The reason I ask is because I have to get the sucker down into my basement, via. the bulkhead steps. If I put a pair of 2x8's on the steps to serve as skids, I can strap the crate and lower it down with my tractor bucket (give me hydraulics or give me death). But this will require leaning the crate over quite a bit.
Hmmmm....
  #63   Ban this user!
Old 02-19-2009, 02:57 AM
skullworks is on a distinguished road
mine was held by two 1/4" bolts...
it held good - but crate was never stressed - it was always supported on a forklift.
  #64   Ban this user!
Old 02-19-2009, 05:55 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
It's a pretty sturdy crate. The mill is securely bolted to the base. Make sure your strap is between the middle and the base as that is strongest point of crate. You COULD remove top and sides of crate and leave mill on skid.
You also could easily disassemble mill into 4 carryable segments: Base, table/saddle, head and column. Read up on disassembly here:
http://www.arceurotrade.co.uk/projec...on%20Guide.pdf
The mill will come on an 18 wheeler. It will need wide enough streets to be able to get to you or you will have to meet driver with your tractor. I had to do this. The crate fit into the bucket of my neighbor's Kubota.
Grizzly's approx $100 shipping fee sure beats Novakon's $700 or Syil's $400. This heinous shipping differential is ONE of the reasons that I did not BUY the Syil SX3 and chose instead to roll my own.
CR.
  #65   Ban this user!
Old 02-19-2009, 06:13 AM
project5k's Avatar
project5k is on a distinguished road
yea, mine came all in one big chunk, all put together that is. you can try and do the skid thing, but that sounds like the riskier way to do it..
if you can, i would pull it apart and carry it. your gonna wanna take it apart to clean it up anyway, and if your gonna start your conversion right away, then you might as well have it apart...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  #66   Ban this user!
Old 02-19-2009, 07:47 AM
I bought my drill press from Grizzly a couple of years back so I know the drill wrt. truck shipment.....
I pitty the poor truck driver that tries to come down our skinny 800' gravel driveway in the woods. Even the propane guy got stuck this winter....
I've got a pretty good situation at work. I just have it delivered to the company and have the guys drop it in the back of my truck with a fork lift. I'll have to pull the truck cap for a few days....but that's not really an issue. I made quick change forks for my little tractor, so my thought was to rig the crate down the bulkhead with chains and straps, etc... Tipping the crate 30 degrees would put the hardware mounting the crate to the base to the test though, that's why I inquired about it.
Then again.....
We have an area (old garage attached to the little house turned office) that we use to store customer samples, maybe I'll plop the crate in their and disassemble the mill and take it home in pieces. Have to check with da boss on that one though. This would probably be easier, but I don't like involving to many people at work in my personal business.
Decisions, decisions....
  #67   Ban this user!
Old 02-19-2009, 07:55 AM
Grizzly paint chips really easily. If you disassemble at work--Wrap everything up in towels to protect it. Maybe you could clean off the red grease there too.
CR.
  #68   Ban this user!
Old 02-19-2009, 08:05 AM
thanks for the heads up guys....
we'll keep you posted...
3/4 or 1" acme screws darth442 Want To Buy...Need help! 4 12-28-2008 05:11 PM
acme screws cueshark Open Source CNC Machine Designs 3 09-18-2007 10:05 PM
CNC conversion w/ acme screws magma-joe Bridgeport and Hardinge Mills 3 07-08-2007 07:21 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
ACME Screws in the UK TonyWood DIY-CNC Router Table Machines 9 11-30-2005 03:23 PM
