| They make up for errors in alignment while allowing the motor to spin without excessive friction. Unless you can be sure that : a) motor and driven shaft are perfectly parallel. b) motor and shaft are aligned about the center c) whatever you use to couple fits both shafts without slop and it's bores are aligned as above you will really want to use a coupler. Or you could waste a bunch of time "making your own", having problems which you can't be sure might be the fault of the couplers, or might be something else. Sometimes $20 (or $60 for three of em) is cheap compared to the headache and frustration they save. |
| If you're going to direct-couple the motors to any other shaft, you NEED them. If you don't, and you don't get the shafts PERFECTLY aligned, you will eventually break one shaft or the other. You can make your own Old-style couplings very easily, using aluminum round stock, and a slab of 1/2" UHMW. Just mill a 1/4" wide by 1/4" deep slot on each side of the UHMW, with the slots 90 degrees to each other, then mill the round stock with a single 1/4" wide by 1/4" high "rib" across one face. Make the rib a snug sliding fit in the slots in the UHMW. Drill the round stock down the middle for the shafts, and drill and tap for a set screw. I made a set years ago, and they were zero backlash, and worked flawlessly. Making them larger diameter (mine were 1-1/2") makes the dimension less fussy. Regards, Ray L. |
| Well, it's been nearly 3 years with the solid couplers and no damaged bearings or broken shafts ![]() Simple to make, dirt cheap and zero backlash. I wasn't worried about my skills to make sure everything was parallel but the hobbyist might want to go with the flexible couplers instead. One of the reasons I give a link on my website. Keling sells a couple of nice looking coupler types. Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
Three years? That's just about how long mine lasted before the first motor shaft snapped. You may have just jinxed yourself! :-) Solid couplings will work, *if* everything is lined up really well. But that is hard to achieve (and even harder to prove you've achieved it), and the couplings I described are cheap and easy to make. Cheap insurance, if you ask me. Regards, Ray L. |
| CR. |
#11
| Regards, Ray L. |
#12
| One of the oldest and most efficient (zero backlash) is the Oldham coupling http://www.mechanisms101.com/oldham.shtml They start at about $8 in the Misumi catalogue. I have found that applications that use aluminum Helical with in any kind of medium/high torque servo, they usually end up fracturing due to metal fatigue, and end up putting on a Stainless version. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| use satellite dish actuator motor as a stepper motor | ozni | Stepper Motors and Drives | 7 | 06-18-2010 08:55 PM |
| Problems with motor stalling due to motor/lead screw alignment | Bimmerkc1 | DIY-CNC Router Table Machines | 3 | 01-24-2010 07:12 PM |
| replacement motor for PML&Kollmorgen DC Brush Servo Motor | fymroger | Product Announcements & Manufacturer News | 2 | 10-24-2008 04:36 AM |
| a paper shredder motor for spindle motor?? | .xXACEXx. | DIY-CNC Router Table Machines | 4 | 06-02-2008 10:17 PM |
| servos motor controled by stepper motor driver? | mike10 | Servo Motors and Drives | 1 | 01-03-2005 06:05 PM |
