#13
#14
I built my conversion for myself but have had to add other options like the link to "flexible" couplers for all the folks that want something easier. I'll add a couple new ones from the great tips posted here. Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
#15
I´ve beens thinking about this problem, and I find HimyKabibble's recipe for a homemade coupler (post #4) is great - I´m going to try it. However, if you are really going to spend around 20 bucks for a coupler, I always thought that I might opt for 2 pulleys+timing belt instead. Don't you think this would be a better solution, and probably cheaper too? With a timing belt you also have another great advantage: you are free to choose a better position for the motors, avoiding "stiking" motors, ending up with stiffer motor mounts and a more compact machine. Am I overlooking some disadvanges? Nelson Last edited by Arquibaldo; 02-03-2009 at 01:46 PM. Reason: cosmetic |
#17
Regards, Ray L. |
#18
Think it was a few thousand RPM, with a large plexiglass platter for the table. Replaced it with a stainless one and all was OK. As far as "perfectly" aligning a motor with a direct coupling, as long as there's a little float in your motor mount holes, once you clamp down the coupler on the motor and 'screw shaft the motor is automatically aligned as well as it can be, then when you tighten the bolts on the motor it keeps it there. (assuming you don't let the motor "free hang" on the screw after you clamp the coupler down and before the mount bolts are tightened) I don't see any problems with it.. I use stainless flexible couplers only because they already came with my 'screws.. <- edit: this assumes, of course, that your motor mount surface is perfectly perpendicular / square to your screw. if not, then it's going to tweak the shaft of both of them as you tighten down the motor mount bolts... |
#19
| ok, i've been using the lovejoys for lots of years in different projects, some are high rpm and some are high torque, and neither have given me any issues, or show any signs of wear.. and besides, even if you were able to wear out the spider... youd notice it long before it completely went away, and you can order new ones for cheap, in different materials even. i've tried, and on my cnc machine, i cant measure any backlash on my lovejoys... further more, if your really that worried about them wearing out, once you have these in, you could allways use the machine to make more spiders, or whatever, but i doubt you'll ever really need them unless something goes very wrong, in which case, your couplers will be the last of your worries. silly question, oldham coupler? is that like what we used to call a rag joint? like what used to be right above the steering box on cars before rack and pinion?
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
#20
| There were slight variations. The link I showed has the Oldham principle. BTW Lovejoy is a Manufacturer and of many various types, not just one. Al.
#21
| ahh, ok didnt know about that one.. steam ships eh.. interesting.. rag joint, yea thats what i was thinking about... lovejoy = Coke in my mind.. they make other flavors, but coke is a generic term used in the south for a carbonated drink, aka soda and pop for the folks up north... we wont go into what a viaduct is.
#23
| if i remember correctly, i ordered mine from mcmaster carr, and i didnt pay more than about 8-10 for mine, and so far, i cant find any backlash in them... i've had my machine for over a year now, and being new when i started, i crashed it a couple times, ran it into a hard stop, stuff like that, and even today, i cant find any slack in them.. infact i had my y axis motor off a few weeks back, and i still had a hard time when i put it back together to get the coupler all lined up(its such a tight fit between the 2 end parts and the spider) i think you'll be very happy with them. I guess you could look at it like this is one of thoes rare times, when the cheaper solution works out just fine in the long run. The only thing that i will say is that when your putting them on, and then mounting your motors, spend a little time getting the motor as lined up as you can, this can only serve to extend the life of all parts involved. (my mounts were slotted to allow for a little adjustment)
| use satellite dish actuator motor as a stepper motor | ozni | Stepper Motors and Drives | 7 | 06-18-2010 07:55 PM |
| Problems with motor stalling due to motor/lead screw alignment | Bimmerkc1 | DIY-CNC Router Table Machines | 3 | 01-24-2010 06:12 PM |
| replacement motor for PML&Kollmorgen DC Brush Servo Motor | fymroger | Product Announcements & Manufacturer News | 2 | 10-24-2008 03:36 AM |
| a paper shredder motor for spindle motor?? | .xXACEXx. | DIY-CNC Router Table Machines | 4 | 06-02-2008 09:17 PM |
| servos motor controled by stepper motor driver? | mike10 | Servo Motors and Drives | 1 | 01-03-2005 05:05 PM |
