Old 02-02-2009, 12:58 AM
MRM RCModels's Avatar
MRM RCModels is on a distinguished road
Best Workbench Casters. Period!
I figure this would be the best place to post this since it deals directly with workbenches. If not, please point me in the right direction.
I just got a lathe and was in the middle of building a workbench for it when I got the idea to put it on casters. Went down to Harborfrieight and picked up some similar to these for $5.99 each. They are rated at 125 lbs each and were ok, but the bench would move if I leaned up against it too hard. Not to mention, I couldn't level the top so it had a consistent "wobble". A perfect solution to this was to upgrade with leveling casters, but these can cost up to $40 each .
I found the exact same leveling casters at accesscasters for less half the cost. I bought four to tryout and am extremely satisfied. So much so that I ordered 8 more for my Mill and RC workbenches. I mounted them using 0.25in steel plate (primed and painted) with 5/16 lag head screws. Worked beautifully .
Just passing the word to those interested,
Kelvin
ID:	74871   Click image for larger version
ID:	74872   Click image for larger version
ID:	74873   Click image for larger version
Old 02-02-2009, 05:10 AM
ojwe is on a distinguished road
Thanks for the head up Kelvin. I've got to get round to building a movable bench for the CNC in the next few months, so I'll try to get my hands on some castors like those. Need to find some in the UK, but shouldn't be too hard.
Owen
Old 02-02-2009, 11:31 AM
Anodizer is on a distinguished road
Casters
These casters look great. I am in the planning stage for some movable tank holding work benches and the leveling part is something I was trying to figure
out.
The weight limit will be all right if I split work areas.
I am now getting the fever to caster everything!
Thanks,
Fred
Old 02-02-2009, 07:40 PM
twoartistic is on a distinguished road
I use a different method
I have a small shop, so moving things around is a great option. The floor is uneven and having a workbench rocking while working is a real pain. I also roll my bench out onto a large concrete pad and work when the weather permits. The pad is less level than my shop floor.
I solved my rocking problems with a very simple solution. I designed my work bench with a tressel type frame distributing the load over 3 casters rather than 4. It has worked out excellent. The top may not be perfectly level with the world, but it is always flat, and never rocks.
Old 02-02-2009, 08:00 PM
DreamFlyer is on a distinguished road
Nice bench and assembly. Looks like total usage weight would be about 500 lbs less the weight of the bench. Do they make that style with larger weight capacity?
Bob
DreamFlyerBob
Old 02-02-2009, 09:31 PM
Bob
Yes, they make 3 sizes. The largest can hold something like 2000+ lbs. I always wondered, the weight capacity is in reference to one or all four; I think it's reference to one. Me and my friend got on top of the bench and it just laughed at us. Together we weight > 500lbs easy.
Old 02-11-2009, 01:32 AM
rezcar is on a distinguished road
Awesome link, thanks!
I build my lathe bench using the HF furniture dolly as a base, the bigger one. But I'll definitely get these casters you posted for my mill bench, my bandsaw could probably use it too.
Old 02-11-2009, 02:07 AM
You're welcome. I had my mill on furniture dolly's too until tonight. I went ahead and bought 12 more for just about everything in my shop heavier than 100lbs. Just got done making the base plate for the mill and RC workbenches. I love this hobby.
ID:	75410   Click image for larger version
Old 02-15-2009, 02:40 PM
While I was on McMaster Carr's site, I looked up some casters like these. $85 for one!!!
Are you getting the 2" caster and are they tall enough, roll well, etc? My garage is all concrete too, I just gotta keep from running over the extension cords all over the place
Old 02-16-2009, 01:30 AM
$85!!! . I am using the 2" versions and they have exceeded my expectations. I also had a extension cord problem until I bought the retractable. It was pricey at $59.99, but I can't live without it now. Might want to look into it.
  #11   Ban this user!
Old 02-16-2009, 03:50 AM
Yeah, that's why I was glad you posted that site with the cheaper prices. I was only curious to see how much they were elsewhere.
I got one of those reels too! Kinda looks like my ceiling...Anyway, don't pull the cord all the way or it'll get stuck and not retract like mine
  #12   Ban this user!
Old 02-16-2009, 11:20 AM
HimyKabibble is on a distinguished road
If ya want one of those, go to Ace Hardware, Sears, K-Mart, Harbor-Freight, etc. For $10-20 you can get a flourescent drop light with a cord reel. Splice an outlet onto the end of the cord, and you've got your extension cord as well. Not *real* heavy duty (18 ga. wire), so I wouldn't run a 3HP compressor on it, but for hand tools and lights, it'd be fine. I got one like this:
http://www.professionalequipment.com...t-work-lights/
but paid $20 for it. I think it came from Harbor Freight.
Regards,
Ray L.
Need Help!- Milltronics Partner 1; Dead after Extended Power Down Period xxcar2 Milltronics 17 07-28-2008 11:54 PM
air casters jack clay Mechanical Calculations/Engineering Design 8 04-30-2007 11:51 PM
V groove casters AustinT Linear and Rotary Motion 4 12-25-2005 12:44 AM
help R2E4 bad period key recycleroy Bridgeport and Hardinge Mills 2 08-17-2005 04:30 PM
Super deal on steel workbench w/casters for $99 CNCPlastic General Metal Working Machines 1 10-26-2004 04:21 PM
