Old 02-01-2009, 08:45 PM
GimpyPaw is on a distinguished road
Sieg X2, can I remove the torsion arm?
The torsion arm is preventing me from lowering the head enough to work items clamped directly to the deck. I was wondering if there would be any ill effects to just removing the assembly?
Old 02-01-2009, 10:35 PM
HimyKabibble is on a distinguished road
Only that it will take more effort to raise the head.
Regards,
Ray L.
Old 02-01-2009, 10:43 PM
mbergmueller is on a distinguished road
And watch your fingers. I thought I was careful....
Old 02-01-2009, 11:13 PM
spring come at you fast? I was about to go remove it, but if there's some particular trick or precaution I'd love to hear it (not that I've never had to pick my fingers up off the floor before, but it's sort of an event I'd like to never repeat).
Old 02-01-2009, 11:33 PM
Just run the head all the way up, to minimize the spring tension, before removing it. It's not a big deal.
Regards,
Ray L.
Old 02-01-2009, 11:47 PM
I was in the middle of something and didn't have the reach. I slowly took the bolt out of the head stock with one hand while holding the torsion arm. I'm a big guy and can hold that tiny spring.
-But my mill is high,
- had to reach over everything,
-bolt started to stick,
-knew something bad was about to happen,
-but I got it in a half nelson,
-wife and child sapped my strengh(or was that my will)earlier,
-it was late,
thunk, ouch. Some how I smashed the hell out of my knuckle near my fingernail. I can't figure out how. Still hurts three days later. Wifes a doc, gives no sympothy.
Torsion box question chuckknigh DIY-CNC Router Table Machines 13 12-26-2010 10:47 PM
Thoughts on MDF & Torsion Box Design the__extreme DIY-CNC Router Table Machines 18 03-02-2009 01:51 PM
How to make a Torsion Box the Right way! Regnar DIY-CNC Router Table Machines 2 06-06-2007 12:18 PM
Foam filled torsion box lgroulx200 DIY-CNC Router Table Machines 10 04-01-2007 10:46 PM
Torsion box discussion posix Mechanical Calculations/Engineering Design 33 02-04-2006 12:04 PM
