Normally, you'd use a plunge rate that is roughly half the feed rate. For the X2, top speed is 2500 RPM, so feed should be around 5 IPM, and plunge rate around 2.5 IPM. If you have a belt drive giving higher RPM, scale these up proportionately.
I normally run 6200 RPM, 12 IPM feed, 6 IPM plunge for slotting with 1/4" tools in aluminum.
Regards,
Ray L.
LinkBack URL
About LinkBacks
