Old 01-27-2009, 04:54 PM
SSfab is on a distinguished road
My version of an X2 conversion.
Well i finally got my X2 this past saturday. This will be a full CNC build and more. I just got done with the my first project "Belt Drive."
Check it out.
Got it home from harbor freight and unpacked it.
This grease is 10x harder to get off when its 10-30deg.
10 minutes later.... Majority of the parts I don't need. (Anyone need anything let me know
Parts I am re-using
And the belt conversion
My belt is a 14" belt instead of the commonly used 13", which just about has the the adjustment maxed out on the "high" side of the pulleys. Also I went with something simple for the motor plate until i get the CNC working i want to make a nicer one.
Heres a video
Stay tuned.
Old 01-27-2009, 05:42 PM
tumutbound's Avatar
tumutbound is on a distinguished road
Looks good.
I've just bought one of these (still awaiting delivery) so I'll be watching what you do to yours.
Regards
Geoff
Old 01-31-2009, 11:36 AM
blades is on a distinguished road
Nice belt conversion. Now tell me about your turbo project! What are you turbocharging?
A few years ago I did a complete (and budget) custom turbo setup on a 4 cyl. S-10 pickup. Turned out great! Thinking about doing the same on my '88 Toyota 4x4.
Old 01-31-2009, 04:25 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Those are cool little mills. I wish I had one.
Best,
BW
Old 02-03-2009, 01:53 AM
Teyber12's Avatar
Teyber12 is on a distinguished road
sub'd!
what are your plans for the cnc parts?
gecko 540 + cnc fusion kit?
Old 02-03-2009, 09:31 AM
Gecko 540 - Yes
CNCfusion - No
I'm going to make up mounts and pretty much everything myself.
I'm machining a new table for longer X travel. Also, I'm trying to locate a base, so i can do a similar setup to Hoss's Y extension.
LMS are out until the end of april.
Grizzly is out for 4-6weeks
I contacted SEIG and they are trying to find one for me. I have a feeling this will be the strap on the project. I can't order ball screws until i have all the axis's done.
Also 8 tool ATC, and full enclosure.
It's going to be a neat little project. I often design and build very unique machines where I work, so achieving what I want should not be to difficult.
Old 02-03-2009, 09:43 AM
Gecko 540 - Yes
CNCfusion - No
Old 02-03-2009, 10:12 AM
asuratman is on a distinguished road
Hello SSfab,
Why did you change to belt drive? To avoid noise? How many HP that spindle motor? Thanks. Asuratman.
Old 02-03-2009, 10:18 AM
tumutbound's Avatar
Here's an alternative way to get increased XYZ travel from an X2.
This is a complete rebuild using only part of the X2. table is a standard Sieg item
(There's mention of a similar thread here on cnczone but couldn't find it)
Regards
Geoff
Old 02-03-2009, 10:34 AM
Originally Posted by asuratman View Post
Hello SSfab,
I did it for a number of reasons
1.Noise is greatly reduced
2.The plastic gears inside the X2 head are very weak. You can ask anybody how bad it sucks when they break.
3. You can get faster spindle speeds with a belt drive.
4. Belts are alot easier to change then gears.
My low speed, at full speed is around 2000 RPM and high is around 4000 RPM
The stock X2 with gears can reach a weak 2500 RPM on high.
  #11   Ban this user!
Old 02-03-2009, 10:35 AM
Thanks for the heads up. Although I'm looking for more travel then that.
  #12   Ban this user!
Old 02-03-2009, 06:10 PM
Well I found out that harbor freight has a division that is strictly parts for their machines. The soonest I could get a base is 6-8 weeks, BUT it was only $23.27 Shipped to my door.
And it will be red instead of green like the gizzly base.
Right from gizzly it was $45 plus S&H
LMS sells them for $59.95 plus S&H
So all in all not a bad deal.
Newest version of Mach3 Version 1.90.065 turmite Mach Mill 3 01-26-2009 10:21 PM
servo conversion vs stepper conversion contractdesign Bridgeport and Hardinge Mills 3 07-26-2008 03:54 PM
VCarve Pro Trial version 3.0: any newer version? monte55 Vectric 2 12-11-2006 06:12 PM
Version 4.01 now available ger21 TurboCNC 0 03-13-2005 03:29 PM
Version 16 Arnie General CAM Discussion 0 11-26-2004 07:38 PM
