I just got a Seig X2 from Harbor Freight and have degreased it and bolted it down. I was playing around with my dial indicator last night and while it took a long time I got the X axis adjusted to within .002 but I can't figure out how to adjust the Y axis. It's off, not by a lot, something like .009. Here is what I got... ![]() So what did I miss? Help please? |
| And of course this means all the x axis adjustments I made are out the window. I needed the practice anyway, right? |
| What diameter circle are you swinging with the dial indicator? The bigger area you can sweep, the more accurately you'll be able to square your machine. Keep working at it! You'll be able to get that .002" out. |
Regards, Ray L. |
| BTW - If you're really going to go to town on this, you should not assume that the spindle is parallel, in either plane (X-Z and Y-Z), to the column dovetails. Adjusting that requires shimming between the two halves of the head, and/or rotating the front half of the head relative to the rear half. It's not unusual for these settings to be off by quite a bit, and will result in the tool moving in X and/or Y as the head is moved up and down. This really HAS to be done *before* tramming X or Y. Regards, Ray L. |
Sort of like watching those instuctional MIT videos, every time I watch one I come up with 2 or 3 new tools I didn't know existed until I found out I couldn't live without one. OK, yes, I do really want to "go to town". How do I measure and adjust the spindle in relation to the column dovetails? |
| check that the column is perpendicular to the table by running the z axis up and down with an indicator in the spindle or attached to the head against the side of an angle plate. then check that the spindle is parallel with the now true column by using a piece of ground drill rod or similar in a collet in the spindle and indicate the rod side moving the Z up and down. A mag base holds the indicator well on the table. I have a test indicator with a long straight tip to use because the ball end could drop from the outer edge of the rod if the y axis tram is real bad. Hopefully it's good to go and they assembled the head parallel with the column so you won't have to bother with this major headache. If so, remove the head loosen the bolts and adjust as necessary. A large granite plate and a height gage with indicator makes it easier. reassemble and double check. then tram away. simple. ![]() a lot more work than most hobbyist want to get into.
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
| Syil/SEIG X2 CNC conversion Axis limit/home switches | IMK1230 | Syil Products | 0 | 10-21-2008 03:50 AM |
| Z axis how to adjust it | cob | Mach Mill | 1 | 07-10-2008 04:59 PM |
| Please Help!3 Axis Milling-How to adjust Z value so it doesn't cut above the material | jerollie | Canadian Club House | 2 | 03-27-2008 06:51 AM |
| How do I tram/align the 4th axis to tailstock? | biomed_eng | DIY-CNC Router Table Machines | 2 | 10-30-2006 07:25 AM |
| Seig X3 Y-Axis | bigbigJimbo | Benchtop Machines | 9 | 07-04-2006 12:02 AM |
