I have 2 dyna mechatronics and i work evry day.....
if you wat the manual send me your mail.
Bye!
Hello!
I recently acquired a Dyna Myte 2400, does anyone per chance know where I might find a manual for this?
Also, I've read some rumors that this CNC is not programmed with M or G codes, can anyone validate this for me??
Thanks in Advance!
Bye!
I have a Dyna 2400 I use at my 'day job'. I have a scan of the manual around somewhere. If I can find it I'll send you a copy.
The Dyna controller is programmed in their on 'conversational' language. It's not too different from GCode. The biggest problem is the very limited 900 line memory. Several years ago I wrote a 'drip feeding' program to send it commands one at a time via the serial link and this worked OK. Depending on your firmware version it would work 90% of the time.
A few years ago I converted it to Mach III and have not looked back. I used all the stock drives and power supply and a home-made opto-isolated break out board (so the stock wiring just plugged right in.) You could use any available BOB though. I have a SmoothStepper from another project that I'm just waiting to try out on it too, so I can get away from being tied to the parallel port.
Jeff Birt
I'm not sure if that was directed at me or if it was even called for, period...(for free, unlike some it seems...)
Hmm...I put this up for download in April and mentioned it here on CNC Zone but I guess did not update this thread. Seems like there may have been a few different requests about the same time. Here is the download URL.
http://soigeneris.com/Documents/Dyna2400_Manuals.zip
Jeff Birt
the link above doesn't work for me. Can somebody check or verify, please?
Göran
Sorry, I was trying to make the docs free to all but outside links to other websites are not allowed. If you replace 'cnczone' in the link with 'soigeneris' you should still be able to download them.
Jeff Birt
I just got one these machine, I can't get the link to the manuals download to work even with the substitution in the url...is it me or is the link broken?
Nope they are still available you need to do the following take this URL:
http://cnczone.com/Documents/Dyna2400_Manuals.zip
remove this part: cnczone
and replace it with : soigeneris
I know it is a PITA but thems the rules...
Jeff Birt
