Old 12-20-2008, 12:20 PM
isaac338 is on a distinguished road
face mill size for X2?
My X2 is listed as having a max face mill capacity of 1 1/8", but the local metalworking shop only sells 2" indexable face mills. Am I flirting with disaster buying a 2" face mill for this small mill?
LMS sells one that's only 1 1/4", which is still over size, but I'd like to buy it locally for various reasons.
Any advice?
Old 12-20-2008, 12:41 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
Are you still running the stock plastic gears or a belt conversion?
If stock I'd stick close to the manufacturers specs, that's what they are for.
If you have a belt drive, a 3 inch is possible.
I ran a 1 3/8 face mill in cast iron with the stock gears on low, carefully.
I switched to a belt drive after pushing my luck running the 3 inch and broke a couple teeth.
The belt drive lets you go beyond factory specs but take note that it also
tops out at 60% higher speeds than the factory had in mind so some bearings
might not hold up.
I lucked out, still running the stock bearings at 6100 rpm. Knock on wood.
Hoss
ID:	71905   Click image for larger version
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 12-20-2008, 01:43 PM
The Blight's Avatar
The Blight is on a distinguished road
Thats just amazing for such a small machine. I'm glad your around Hoss, so that we get to see what this machine can do.
Old 12-20-2008, 01:45 PM
might not hold up.
Hoss
Hoss,
Good info. I bet the 2" would work if I took it slow..
My mill came with steel gears, but I had to switch to plastic with the R8 conversion kit (mill came with MT3). The steel gears wouldn't fit on the R8 spindle. Hopefully I'll have enough money for a lathe soon, at which point I can bore the gears out.. or I could do it on the mill.. or I could make a belt conversion. So many options!
Old 12-21-2008, 01:02 AM
uptoolateman is on a distinguished road
Littlemachineshop carries the steel gear conversion kit for the R8 spindle now, they also sell the belt conversion kit.
face mill fourperf Haas Mills 11 12-15-2008 03:07 AM
Which Face Mill to get? Willyb Tormach PCNC 21 11-12-2008 08:23 PM
x2 and face mill size krymis Benchtop Machines 11 12-19-2007 02:56 PM
fastest way to face mill DerHammer General Metalwork Discussion 18 11-15-2007 02:23 AM
Face Mill camtd PTC Pro/Manufacture 1 04-28-2006 06:51 PM
