Results 1 to 6 of 6
Thread: Help with rotary table
    Oct 2008
    I have a rotary table for a mill and would like to hold a 5" diameter cylinder using this rotary table. I do not need to move at a high rpm (7 - 8 rpm max)
    I also have a 3 jaw chuck available.
    Does anyone have any recommendation for the kind of fixture needed to support such a cylinder (5" diameter)?
    thanks in advance
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Smile
    This chuck has a 4.92" through hole.
    http://grizzly.com/products/16-4-Jaw...uck-D1-8/G9871
    Jeff...
    Oct 2008
    thanks Jeff. this one maybe too big for my app
    Feb 2007
    U.S.A.
    Smile
    What about a fixture made out of a tube welded to a plate.
    Then bore the tube ID to the correct diameter after you mount it to your rotary.
    It would be perfectly centered as long as you dont remove the fixture from the rotary.
    Jeff...
    Jun 2006
    Stavanger, Norway
    What size is the rotary table, what size is the chuck.
    Will the chuck hold the cylinder with the inside jaws, if yes then make a backplate to fit the chuck to the RT.
    Phil
    Quote Originally Posted by woodsnskins View Post
    thanks in advance
    Feb 2008
    UK
    My thought here - more questions than answers i'm afraid!
    1. Help with rotary table
      By woodsnskins in forum Linear and Rotary Motion
      Last Post: 12-18-2008, 05:58 AM
    2. Rotary Table For SX3
      By DadHav in forum Benchtop Machines
      Last Post: 10-30-2008, 11:37 AM
    3. How do you use a rotary table?
      By ranchak in forum General Metal Working Machines
      Last Post: 01-30-2008, 11:30 PM
    4. Rotary table
      By Piobaire in forum HURCO
      Last Post: 08-22-2007, 08:30 AM
    5. Useful for Rotary Table?
      By Ken Stuempge in forum Mechanical Calculations/Engineering Design
      Last Post: 02-12-2006, 10:16 AM
