Old 11-16-2004, 06:57 PM
jleiwig is on a distinguished road
high speed rotary table?
Is this even possible to do some small cnc lathe operations on the homier mini mill with some sort of small high speed chuck or rotary table tye piece?
Old 11-17-2004, 09:39 PM
Gold Member
JFettig is on a distinguished road
are you looking to do real turning or milling round stuff? I dont think real turning will work, and high speed spinning while milling will work either, but if you wanna spin a part rather fast and be somewhat precice, make a plate to mount a lathe chuck strait to a stepper or use some gear reduction.
Jon
Advise needed for rotary table conversion spoiledbrat DIY-CNC Router Table Machines 2 05-11-2005 02:34 PM
High speed rotary coolant coupling CAMME Mechanical Calculations/Engineering Design 6 02-21-2005 08:14 PM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
5th even 6th axis? how does it work ToMMY2ooo General Metal Working Machines 10 10-04-2004 03:58 PM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 05:30 AM
