did you use some locktite on the screw that holds the bearing
I have this issue that keeps popping up every so often. I have a Mini Mill built from LittleMachineShop parts, which usually runs smooth and true. But then the, " x" axis bearing comes lose, as to chatter under less than medium hand speed loads. I have re tightened it about twenty time or more only to have it go wonky again. Any ideas as to how I can simply correct this issue.
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
That's a fabulous idea. Seriously I didn't even think of that, thanks.
no problem, glad i help
Try to add another nut to the end if you still have enough screw end. You can tightened the outer nut to secure the x axis bearing in place.
By doing so, you won't have problem with having to work hard to get the nut out as the locktite may stick so well. Just a thought.
