Old 11-24-2008, 10:42 AM
Thorpydo is on a distinguished road
X3 Maintenance
So I'm somewhat new to the game.
I've got a CNC'ed X3 running flood coolant. I've only run a couple parts on it so far. The table is starting to get some spots on it from (I believe) the coolant. Should I wipe down the machine after use, every time? I know I need to start oiling the ways. What should I use? Am I going to have a problem with oil in my sump and how can I combat this?
I've also got a small amount of surface rust on the column. What do I do prevent this? I know WD-40 is not the solution but I don't know what to use or where to get it.
Thanks,
Adam
Old 11-24-2008, 01:55 PM
ataxy's Avatar
ataxy is on a distinguished road
What ratio do you use for your cutting fluid? Yes you should clean your machine after a job.
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 11-24-2008, 09:48 PM
Fluid is blasocut 2000 universal. I mixed a ratio of 8.33:1. Directions were anywhere from 5:1 to 20:1.
I figured that as it evaporates I can easily add water until I've reached 20:1. As I've read, adding concentrate is another story because it doesn't dissolve if its added to a already mixed solution. Could I mix up a small batch of something like 3:1 or 4:1 once I've reached that point, bringing the 20:1 down so that I can simply add more water?
Thanks,
Adam
Looking for Maintenance Manual bob1371 Fanuc 3 06-17-2011 10:19 PM
Mazak PLC maintenance sting_dot Mazak, Mitsubishi, Mazatrol 3 05-03-2011 10:20 AM
Die maintenance ??? dpotts Casting Metals 0 03-31-2007 03:53 PM
CNC Maintenance shinerbttu Employment Opportunity 0 05-17-2006 10:50 AM
Maintenance Muddywoman Printing, Scanners, Vinyl cutting and Plotters 1 11-13-2004 09:24 PM
