Old 11-23-2008, 03:07 PM
scampo77 is on a distinguished road
questions about oil for a lathe
very very new to this so please dont hit me.
i have recently come across a myford lathe im not sure what qualifies it as a mini lathe but im pretty sure it is a ML7 mini lathe. i figure the fact that i can pick it up and move it around qualifies it as a mini lathe.
i am pulling all the pieces apart and cleaning out old metal shavings and tryiing to file off rust. my question is about a small automatic oiler ontop of the head stock. i have 2 of them. i pulled them apart and cleaned everything out. they seem to consist of a couple small tubes a spring and a check ball. i have 2 questions about them. #1 what kind of oil should i be putting in them and #2 how do i know if they are working correctly?
i have oiling points all over the lathe and a few of them are smashed apart. they are about 1/4 inch in diameter and seem to be made of brass with a ball and spring in the middle. where do i find these to replace the smashed ones? and where do i find an oiler for them? and is there a correct name for the oiler or the oil points?
Old 11-23-2008, 04:22 PM
i found a picture online of these.
http://www.rdgtools.com/acatalog/info_847.html
mine are a little different but not by much. i cant order these ones because they are out of stock.
Old 11-23-2008, 04:37 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
I haven't seen those in a while
A good way oil would work.
you lift the little lever on top to get the oil dripping, adjust the knurled knobs
for more/less.
The sight tubes if they are clear should let you see the drips.
remember to flip them back down when your done working or it'll drip till empty.
1 drip every 5 secs should suffice.
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 11-24-2008, 10:51 AM
but what kind of oil should i use? and what about the oiling points?
Old 11-24-2008, 11:27 AM
NEATman is on a distinguished road
Try taking a look here:
http://www.lathes.co.uk/myford/index.html
Tons on info.
Keith
Old 11-24-2008, 02:12 PM
philbur is on a distinguished road
I think a Myfrod ML7 weighs something in excess of 200lbs so if you are picking it up and moving it around it may not be a Myford ML7. The lathe link that Hoss2006 gave will show you pictures of different Myford lathes. It may be an ML10.
Just a thought
Phil
Old 11-24-2008, 02:28 PM
thank you for the link there its lots of info here. it is for sure a ML7 not a super 7 or ML10 (i guess im just a big guy). i have read a bit but they dont seem to offer these oiling pionts i need or the spring loaded oiler.
and i still am unclear what kind of oil to buy. right now im just using auto trans fluid
Old 11-24-2008, 03:04 PM
have you been here:
http://www.myford.com/
Phil
Old 11-24-2008, 03:30 PM
Here's a lube chart for a Super 7. It includes recommended lubricants.
Phil
Name:	myford lube.jpg‎
Old 11-24-2008, 03:32 PM
hoss2006's Avatar
Just a thought
Phil
Thanks, I post a lot of links but can't take credit for NEATman's good catch
Here's one source for some conventional Way Oil from Enco.
They have lots of other brands/types including ISO VG 68 Way Oil.
Hoss
  #11   Ban this user!
Old 11-24-2008, 03:50 PM
Sorry NEATman, I should have checked first.
Phil
  #12   Ban this user!
Old 11-24-2008, 06:18 PM
HimyKabibble is on a distinguished road
For a hobby machine, it really makes very little difference what oil you use, as long as you use oil. Any good motor oil or ATF should be fine, or you can buy way oil from Enco, MSC, etc. for about $15-20/gallon.
Regards,
Ray L.
C6 lathe questions MadMax Syil Products 2 12-13-2007 11:25 AM
MasterCam lathe Questions mefull Mastercam 12 09-16-2006 09:38 PM
new guy with a cnc lathe general questions LOGBOSS General Metal Working Machines 1 05-07-2006 04:41 PM
Mach3 lathe questions JFettig Mach Lathe 5 03-16-2005 05:43 PM
Lathe machining questions devinchi General Metal Working Machines 5 02-25-2004 10:17 AM
