Old 11-04-2004, 05:31 PM
DAB_Design is on a distinguished road
Examples of limit/home switches
Does anyone have any pictures or links to what they are using for limit/home switches. And maybe photos of how they are mounted and triggered.
Old 11-04-2004, 06:09 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I will soon as I have to add them myself.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-04-2004, 08:02 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Here's an image of the Z axis' limits; they are inexpensive micro switches from Mouser.com. which are mounted back to back. Switches are all wired in series and are Normally Closed. The switches are screwed into the Z chassis and the moving body bumps into the switch's lever. In this image Z is about to trigger a limit. There is a stop on the top end of the axis which hits the top switch's lever when the Z is all the way down.
Simple cheap effective
(There are some pics on my site of some embarrassingly shoddy ones made from coat hanger wire and cheapo switches...but they worked .)
Oops Just realized this is a mini-mill thread, not DIY, oh well
Old 11-04-2004, 09:15 PM
sol, actually, I'm glad you posted it. Any and all ideas will help with what I decide to go with.
Is that only 1 lead going to the switches? How are the wired to the controller?
Old 11-04-2004, 11:15 PM
Gold Member
JFettig is on a distinguished road
Heres a pic of one of my home switches(can be used as limits too)
heres a video in quicktime format(what my camera saves as) search google for quicktime alternative if you dont like quicktime.
http://jfettig.wc101.com/cnc/homing.MOV
Jon
Old 11-05-2004, 02:28 PM
Swede's Avatar
Swede is on a distinguished road
Here's what I did for some cheap, adjustable limit switches:
See http://www.5bears.com/cnc05.htm for details. If you can protect them from swarf and oil, they're simple to do.
Old 11-05-2004, 07:27 PM
sol sol is offline
Gold Member
The switches have two wires to them; the orange sheathing encloses the wires, jpeg compression kind of smeared the detail.
They are wired to a parallel port input pin (pulled high w/ a 10K resistor) and to the parallel port's ground. Since the switches are normally closed the p.p. pin sees low until any one of the switches is hit and opened. Then the pin goes high and the software stops the Geckos.
Here is a recent thread that goes into a bit of detail...
http://cnczone.com/forums/showthread.php?t=5879
Help with limit switches and Xylotex board dowling177 Xylotex 5 11-26-2008 02:51 PM
Limit switches itsme General Electronics Discussion 5 05-01-2005 05:02 PM
Pneumatic SS switches - home/limit? Swede General Electronics Discussion 3 01-31-2005 08:19 AM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-29-2004 11:22 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
