Old 11-03-2004, 09:07 PM
oldpoopie is on a distinguished road
need help with stepper motor
Hey all. This is my first post. I've just become entrenched in a CNC conversion of my HF mini-mill. I plan on using a ballscrew on the Z and I just purchased 4 brand new surplus steppers. They are nema 34 Sanyo-Denki type 103-845-1111, 4 wire. The only marking on the endcaps say 4.2v, 4.7a, and 1.8deg/step.
What I want to know is what will be required to drive these? What should I use for a power supply, and which stepper driver would be appropriate?
Thanks in advance for any help you could give.
-Justin
Old 11-03-2004, 09:11 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I think you will have a problem having only 4 wires, you really want a 6 wire system.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-03-2004, 09:21 PM
why 6 wire? With 4 wires, arent these motors bipolar? Most stepper drivers I've seen via google have been bipolar, like the zylotec.
Old 11-19-2004, 02:06 PM
George McCre is on a distinguished road
Try the open source forum
If you are wanting to build a drive yourself they have excellent schematics for bipolar and unipolor motors. At the very least there is a lot of very usefull information on the two. Zylotex has a three and four axis driver that is reasonably priced. I am sorry but I don't have the link handy. I am currently doing the research on building my own homebrew, a small one at first to make the driver boards for a larger CNC router.
Old 11-20-2004, 02:50 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Given 4.2V 4,7A NEMA 34 bipolar steppers, you would appear to have motors which will be a very good match to the Gecko drivers. The Xylotex drivers are limited to 2.5A and 30V, and would be way under powered for these motors.
Are these single stack or double stack motors?
Go to geckodrive.com, and read the PSU white paper under the support menu. Actually read the whole stepper white paper. Marris put a lot of effort into this reference, and it is very informative.
Regards,
Mark
www.wrathall.com
Old 11-20-2004, 08:04 AM
Gold Member
JFettig is on a distinguished road
Yeah, the wiring is black white, red and green. Gecko drives are perfect, see if you can get ahold of a 80v power supply that supplys enough current for all of them.
Jon
stepper motor load resistor and figuring out phases? drtuto General Electronics Discussion 7 03-19-2005 02:53 PM
Souce for NEMA 42 stepper motor? Mueller Stepper Motors and Drives 2 03-06-2005 07:59 PM
Stepper Motor Selection dberndt Stepper Motors and Drives 7 12-06-2004 06:50 AM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-01-2004 11:31 PM
Which stepper motor should I buy Graham S FAQ of CNC Machine building 0 08-27-2004 05:58 AM
