Old 11-03-2004, 08:48 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Converting a mini from geared to belt driven
Anyone know how I could converting my mini mill from geared to belt driven spindle.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-04-2004, 10:15 AM
kaderick is on a distinguished road
I have done two of them, both using treadmill motors. ONe of them used the xl timing pulleys, and the other was a small v belt. I took a plate, and mounted that to the original motor mounts, then decided where the motor would fit. I turned some standoffs to elevate the motor so the pulleyw would align. Get some pulleys in the correct ratio, you will have to bore out the one to fit the spindle pulley, but you will find one with the correct bore for the motor pulley. Its really easy.
servo driven mini mill on ebay qsacracer Benchtop Machines 6 06-28-2005 03:29 AM
Belt reduction questions Please help!? Bird_E General Metal Working Machines 3 11-26-2004 07:55 AM
Belt Drive V's Ballscrews MrBean DIY-CNC Router Table Machines 12 10-13-2004 02:30 PM
Timing belt driven router - updated pictures deanc500 DIY-CNC Router Table Machines 19 04-10-2004 09:12 AM
Converting Mini Mill to CNC(HF44991) NAKD Benchtop Machines 5 02-04-2004 07:22 PM
